BPi M1, gigabit fix?
HI, after using my Banana Pi for over a year with a Bananian and OpenMediaVault as a small NAS, it’s finally time to do a software upgrade. I would also like to use the Gigabit fix, but I shied away from it at the time, because you had to compile your own kernel (and I have no idea of ​​that at all). Is there now an image that uses the Gigabit fix out-of-the-box? Or is there a good guide how to get the fix? Please help. Thanks! I didn’t find the right solution from the Internet.
References: https://forum-bpi.de/viewtopic.php?f=7&t=264
Corporate Motion Graphics Example
You can take the bracelet and install OpenMediaVault the instructions can be found
https://forum-bpi.de/portal
or a finished img. from OpenMediaVault https://forum.openmediavault.org/index.php/BoardList/ https://sourceforge.net/projects/openmediavault/files/Other%20armhf%20images/
