BPI M1 and BPI LCD 7" (HC070TG38035)
Hi.
Has anyone connected BPI LCD 7" module (HC070TG38035) with BPI M1 board successfully?
I have tried with an Ubuntu 16.04 desktop image and used driver gt9xx. The touch is detected, however is not calibrated and mouse pointer is not correctly possisioned on the screen. I tried to calibrate touch using xinput- calibrator with no results.
Could anyone suggest an image or driver in order to get this device working correctly?
Regards
Here you can check some findings with a similar display/situation.
Hi.
Thank you for your help. I will check the post and let you know my findings.
Regards.
