[BPI accessories] BPI Prototyping Pi Plate
Product Specification:
Produce Overview: The Prototype development module is designed specifically for the Banana Pi. The module suitable enthusiasts and user can weld peripheral to the module;The module expand some amphenol connector and some SMT, so the user can finish prototype test easily.
Product Feature: Expand common GPIO through amphenol connector Expand common GPIO through Female Header Connector Set aside a large amount of welding hole
Port: I2C amphenol connector Female Header Connector SPI amphenol connector SPI Female Header Connector Serial port amphenol connector Serial port Female Header Connector 3.3V Vcc 5V Vcc
Product Parameters: 3.5mm Amphenol Connector 2.54mm Female Header Connector
Typical Application: Hardware weld primer Prototype experiment DIY enthusiasts
How to use: Insert the Prototype development module to Banana Pi, Pay attention don’t make the direction reversed! The correct direction of insert module is above the Banana Pi’s PCB.
