BPI:4.0: BPI-R64 for 5G + 4G LTE+Wifi AC+Gigabit for Converged communication router
BPI:4.0: BPI-R64 for 5G + 4G LTE+Wifi AC+Gigabit for Converged communication gateway
PCBA design
PCBA interface:
with case
The product adopts MTK7622 quad-core 64-bit A53 chip design, with the main frequency up to 1.35g. Onboard 1-2g DDR memory and 8g eMMC storage.Can support OpenWRT,Linux,Android operating system, in-depth customization of xiaocao technology integrated communication software platform.Provide a complete fusion communication, multi - link communication solution.And supports IoT extensions.Free access to IoT applications.
Main fcunction:
  1. MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53
  2. 1x5G port , Use USB 3.0 or PCIe bus.
  3. 4x4G LTE , support OpenMPTCProuter Multiple Merges protocol.
  4. 5xGigabit port. support VPN ,router function.
  5. wifi 802.11 b/g/n/ac function support.
  6. IoT expanding application with 26 PIN GPIO
  7. (1-2)G DDR and 8G eMMC flash
  8. M.2 key B interface
Front:
Back:
Also support IoT expanding application
Product application direction:
it can be applied to communication vehicles, command vehicles, smart police cars, medical rescue vehicles, engineering and emergency vehicles (water, electricity, gas, fire trucks, etc.), cargo transport and passenger vehicles, high-speed rail, mobile finance and other scenarios.
product feature:
  1. G high-speed access, 5G technology has higher throughput, providing a higher possibility for the Internet of everything, real-time.
  2. 4g Multiple Merges support, network speed guarantee: multi-channel cable, 4-channel 4G wireless link can be aggregated to form a high-speed, stable and safe high-capacity upstream and downstream channel. Support 4G wireless network mixing of all mobile/unicom/telecom operators, and support dedicated line /DAL cable link and satellite link.
  3. High stability and convenience: the data transmitted by the front end can better optimize and configure the load of the links, so as to effectively avoid the link congestion caused by blind data transmission, maximize the use of all available channels, and form a stable communication link.
  4. High security: after the original data is unpacked and encrypted by the fusion device, it is sent to the server through different channels. The load of each link is dynamically adjusted according to the communication capacity of each channel. The terminal and server are also equipped with VPN to protect the data up to 4 times.
  5. Industrial-grade AP access: industrial-grade AP module is built in the device, suitable for WIFI device access/bridge and other scenarios in various environments.
  6. Enrich the IoT extension interface,support Zigbee,Z-Wave,NB-IoT,LoRA,PLC…
Base on BPI-R64 design ,more about this design hardware :
http://wiki.banana-pi.org/Banana_Pi_BPI-R64
welcome for OEM&ODM , please send mail to judyhuang@banana-pi.com
1U standard rack design:
Front:
Back:
development: OpenWRT on board
