Bannana PI with UHF RFID
Hello,
I’m sorry if I added a topic to the wrong branch. I want connect banana pi with UHF RFID, to use this on track go-carts.
I know that i need chipy UHF: 865-868 MHz. Antenna UHF.
I steel don’t now what reader i need to use and how connected this with banana pi.
I will be greatefull for help me.
Best regards, Kamil
can you give as UHD RFID datasheet . i can let our R&D to check it .
I’m a beginner with banana and UHF RFID. What datasheet to check it you need ? :slight_smile: I can connect directly to the antenne with banana pi, do i need a reader UHF RFID ?
we need UHF RFID spec , and check how to contact it to banana pi , as i know, it it easy to add ,.
I don’t know now what reader or antene use to connect with banana pi :frowning:, and what specification send you :frowning:
I only find specification at uncle google:
what will be connected to banana pi Reader or antenna? I ask team from rfid.
OK , i will let our R&D check this documents . or you can mail to , 肖[email protected] ,
UHF RFID is usually a USB or UART interface, you can buy one on Ali, but you need to debug the drive by yourself
https://tr.aliexpress.com/wholesale?catId=0&initiative_id=AS_20170801162342&SearchText=UHF+RFID
Hello, I get specification. This email: [email protected] is correct to send that?
