Bananapi m3 cpu broken?
(zhu) #1
used lasted image but rebooting always:
[    6.438222] [<c090f3e8>] (secondary_start_kernel+0x10c/0x130) from [<4090e9d4        >] (0x4090e9d4)
[    6.438219] CPU6: stopping
[    6.438219] [<c0017f9c>] (unwind_backtrace+0x0/0x128) from [<c09123ec>] (dump        _stack+0x20/0x24)
[    6.438219] [<c09123ec>] (dump_stack+0x20/0x24) from [<c0016410>] (handle_IPI        +0x17c/0x308)
[    6.438219] [<c0016410>] (handle_IPI+0x17c/0x308) from [<c000a3d4>] (gic_hand        le_irq+0xa4/0xb4)
[    6.438219] [<c000a3d4>] (gic_handle_irq+0xa4/0xb4) from [<c00103c4>] (__irq_        svc+0x44/0x78)
[    6.438219] Exception stack(0xe693df68 to 0xe693dfb0)
[    6.438219] df60:                   00000003 c0ddf1a0 00000000 00000000 e693c        000 c0f20908
[    6.438219] df80: c0923724 c0de4010 4000406a 410fc075 00000000 e693dfbc e693d        fb0 e693dfb0
[    6.438219] dfa0: c0011588 c001158c 60000013 ffffffff
[    6.438219] [<c00103c4>] (__irq_svc+0x44/0x78) from [<c001158c>] (default_idl        e+0x38/0x40)
[    6.438219] [<c001158c>] (default_idle+0x38/0x40) from [<c00119bc>] (cpu_idle        +0xac/0x108)
[    7.508601] SMP: failed to stop secondary CPUs
[    6.438219] [<c00119bc>] (cpu_idle+0xac/0x108) from [<c090f3e8>] (secondary_s        tart_kernel+0x10c/0x130)
[    6.438219] [<c090f3e8>] (secondary_start_kernel+0x10c/0x130) from [<4090e9d4        >] (0x4090e9d4)
[    6.438221] CPU4: stopping
[    6.438221] [<c0017f9c>] (unwind_backtrace+0x0/0x128) from [<c09123ec>] (dump        _stack+0x20/0x24)
[    6.438221] [<c09123ec>] (dump_stack+0x20/0x24) from [<c0016410>] (handle_IPI        +0x17c/0x308)
[    6.438221] [<c0016410>] (handle_IPI+0x17c/0x308) from [<c000a3d4>] (gic_hand        le_irq+0xa4/0xb4)
[    6.438221] [<c000a3d4>] (gic_handle_irq+0xa4/0xb4) from [<c00103c4>] (__irq_        svc+0x44/0x78)
[    6.438221] Exception stack(0xe692bf68 to 0xe692bfb0)
[    6.438221] bf60:                   0000000f c0ddf1a0 00000000 00000000 e692a        000 c0f20908
[    6.438221] bf80: c0923724 c0de4010 4000406a 410fc075 00000000 e692bfbc e692b        fb0 e692bfb0
[    6.438221] bfa0: c0011588 c001158c 60000113 ffffffff
[    6.438221] [<c00103c4>] (__irq_svc+0x44/0x78) from [<c001158c>] (default_idl        e+0x38/0x40)
[    6.438221] [<c001158c>] (default_idle+0x38/0x40) from [<c00119bc>] (cpu_idle        +0xac/0x108)
[    6.438221] [<c00119bc>] (cpu_idle+0xac/0x108) from [<c090f3e8>] (secondary_s        tart_kernel+0x10c/0x130)
[    6.438221] [<c090f3e8>] (secondary_start_kernel+0x10c/0x130) from [<4090e9d4        >] (0x4090e9d4)
[    6.438217] CPU7: stopping
[    6.438217] [<c0017f9c>] (unwind_backtrace+0x0/0x128) from [<c09123ec>] (dump        _stack+0x20/0x24)
[    6.438217] [<c09123ec>] (dump_stack+0x20/0x24) from [<c0016410>] (handle_IPI        +0x17c/0x308)
[    6.438217] [<c0016410>] (handle_IPI+0x17c/0x308) from [<c000a3d4>] (gic_hand        le_irq+0xa4/0xb4)
[    6.438217] [<c000a3d4>] (gic_handle_irq+0xa4/0xb4) from [<c00103c4>] (__irq_        svc+0x44/0x78)
[    6.438217] Exception stack(0xe6965f68 to 0xe6965fb0)
[    6.438217] 5f60:                   00000001 c0ddf1a0 00000000 00000000 e6964        000 c0f20908
[    6.438217] 5f80: c0923724 c0de4010 4000406a 410fc075 00000000 e6965fbc e6965        fb0 e6965fb0
[    6.438217] 5fa0: c0011588 c001158c 60000113 ffffffff
[    6.438217] [<c00103c4>] (__irq_svc+0x44/0x78) from [<c001158c>] (default_idl        e+0x38/0x40)
[    6.438217] [<c001158c>] (default_idle+0x38/0x40) from [<c00119bc>] (cpu_idle        +0xac/0x108)
[    6.438217] [<c00119bc>] (cpu_idle+0xac/0x108) from [<c090f3e8>] (secondary_s        tart_kernel+0x10c/0x130)
[    6.438217] [<c090f3e8>] (secondary_start_kernel+0x10c/0x130) from [<4090e9d4        >] (0x4090e9d4)
[    8.508682] sun8i hotplug: try to kill cpu:1 failed!
[    9.520402] sun8i hotplug: try to kill cpu:2 failed!
[   10.531985] sun8i hotplug: try to kill cpu:3 failed!
[   11.543440] sun8i hotplug: try to kill cpu:4 failed!
[   12.554760] sun8i hotplug: try to kill cpu:5 failed!
[   13.565946] sun8i hotplug: try to kill cpu:6 failed!
[   14.577001] sun8i hotplug: try to kill cpu:7 failed!
[   14.587915] Rebooting in 10 seconds..
(zhu) #2
used stock 3A 5V power.
(ZB) #3
could you please give me the whole log(u-boot + kernel)
