Banana Pi raspberry pi i?
(jackneeson) #1
There is a raspberry pi clone that runs on an Allwinner A20 and has a sata port. Is is supposed to be able to run a modified raspbian image, complete with the raspi-config menu. = Are there any other limitations like hardware that would stop the raspberry pi build of DVBLink from running on another board if that board ran raspbian? If not, then theoretically the Raspbian image for the banana pi should work on the cubieboard2 (as the specs are very similar)
Please help.
I didn’t find the right solution from the Internet.
References:-
https://bit.ly/2L1iKv6
Marketing video service
Thanks!
(bpi team) #2
you can see here:
