banana pi OV5640 camera driver , thank alex do the work.
I think you would find this latest updates on github interesting.
I have also pushed a V4L2 CAP application to capture and/or test OV5640 and OV8865 with the help of OpenCV to save JPG frame.
i, I am using BPI M3 with camera module
https://bananapi.gitbooks.io/bpi-accessories/en/bpim3camera.html,
following the instructions on
https://bananapi.gitbooks.io/bpi-m3/en/bpim3csicamerainterface.html
I am able to capture images from ov8865.
However, following the same instructions for OV5640, How to use OV5640 on BPI-M3:
Step 1: Install git $ sudo apt-get install git
Step 2: Update bpi-tools $ git clone https://github.com/BPI-SINOVOIP/bpi-tools.git5 (NOTE: git5 is incorrect, it should be git) $ cd bpi-tools
$ sudo ./bpi.tools -u -U
Step 3: Use bpi-update to update kerenl $ mkdir update_file $ cd update_file $ sudo bpi-update -c bpi-m3.conf (NOTE: THERE IS NO ov5640 driver in update in bpi-tools) $ sudo reboot
The Kernel did not upgrade.
This is what I have: uname -a Linux bpi-iot-ros-ai 3.4.39-BPI-M3-Kernel #1 SMP PREEMPT Fri Nov 3 01:03:00 UTC 2017 armv7l armv7l armv7l GNU/Linux
ls update_file/ 3.4.39-BPI-M3-Kernel.tgz bpi-m3-ov8865.conf camera.tgz addons.tgz bpi-service.tgz libvdpau_sunxi.tgz BOOTLOADER-bpi-m3.tgz bpi-tools.tgz BPI-BOOT-bpi-m3-ov8865.tgz brcm.tgz ov8865-enable.tgz BPI-BOOT-bpi-m3.tgz bt.tgz ov8865.tgz bpi-m3.conf camera-apps.tgz
I am not sure if it is the driver issue or the camera (ov5640) board is incorrect. I saw in the BPI-M3 schematics CSI-PWDN-F is connected to PD15 pin of A83T, while in the A83T_TABLET_STD_V1_2 schematics CSI-PWDN-F is connected to PE19.
Tried to contact Nora.Lee but she is not helpful, although she showed the video of ov5640.
