Banana Pi m3/m64 laser cut case
Hi all, here is share with you Banana pi M64 laser cut case files, designed with Autodesk Inventor.
The is made from plexiglass sheet, using 2 size, top and bottom red parts has 3mm thinkness, and other middle leyers 5mm. I provide also dxf file ready for laser cut. Here is the Links to download.
Thank YoubananaPi_case_asm
very cool ,thank you share this case.
Improved version of case download here
