Banana Pi BPI-R64 (MT7622) openwrt (Kernel 4.19) Source code on github
What about kernel 5.4?
you can see this pthread:
But this is not permanent solution. Compile procedure very complicated.
I have troubles getting files written and getting settings saved. Here’s what I’ve done:
  1. Compiled the image above.
  2. Zeroed out and written mtk-bpi-r64-SD.img to SD card.
Still I’m getting JFFS errors and nothing is saved after reboot:
[  181.738553] jffs2: Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
[  181.747275] jffs2: empty_blocks 0, bad_blocks 0, c->nr_blocks 16284
Kernel command line is as follows:
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0x11002000 console=ttyS0,115200n1          initrd=0x4400000
0,0x615E36 loglevel=8 androidboot.hardware=mt7622 swiotlb=512           earlyprintk block2mtd.block2mtd=/dev/mmcblk1,655
36,SD,5 mtdparts=SD:768k(mbr)ro,512k(uboot)ro,512k(Config)ro,256k(Factory)ro,32M(Kernel),32M(recovery),1024M(rootfs),204
8M(usrdata),-(bmtpool) rootfstype=squashfs,jffs2
Rootfs is squashfs and is mounted correctly.
[   14.886375] 9 cmdlinepart partitions found on MTD device SD
[   14.892116] Creating 9 MTD partitions on "SD":
[   14.896706] 0x000000000000-0x0000000c0000 : "mbr"
[   14.901911] 0x0000000c0000-0x000000140000 : "uboot"
[   14.907237] 0x000000140000-0x0000001c0000 : "Config"
[   14.912634] 0x0000001c0000-0x000000200000 : "Factory"
[   14.918129] 0x000000200000-0x000002200000 : "Kernel"
[   14.923518] 0x000002200000-0x000004200000 : "recovery"
[   14.929117] 0x000004200000-0x000044200000 : "rootfs"
[   14.934499] mtd: device 6 (rootfs) set to be root filesystem
[   14.941024] 1 squashfs-split partitions found on MTD device rootfs
[   14.947437] 0x000004840000-0x000044200000 : "rootfs_data"
[   14.953329] 0x000044200000-0x0000c4200000 : "usrdata"
[   14.958822] 0x0000c4200000-0x0003ad400000 : "bmtpool"
[   14.964300] block2mtd: mtd0: [SD] erase_size = 64KiB [65536]
[   14.970306] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01 00:01:03 UTC (946684863)
[   14.982279] VFS: Mounted root (squashfs filesystem) readonly on device 31:6.
Here’s df output
root@OpenWrt:/# df -h
/dev/root                 6.3M      6.3M         0 100% /rom
tmpfs                   499.1M     60.0K    499.0M   0% /tmp
tmpfs                   499.1M     40.0K    499.0M   0% /tmp/root
overlayfs:/tmp/root     499.1M     40.0K    499.0M   0% /
  1. @sinovoip could you please help get RW filesystem working?
  2. What are the benefits of squashfs root and overlayfs as RW volume anyway? Should I fall back to ext4 RW rootfs and forget all the hassle with both 4.19 and 5.4 kernels?
