Banana pi BPI-M3-H with allwinner H8 chip Android 5.1.1 Test
BPI-M3 with allwinner A83T BPI-M3-H with allwinner H8 BPI-M3-R with allwinner R58
Yeah, H3 what else. Unbelievable. And you’re the person writing ‘technical documentation’ all the time.
sorry for this mistake :slight_smile: thank you.
You’re welcome. And instead of fixing the whole issue (look at the thread title) you stop halfway in between. And this also explains why you’re not able to write correct ‘technical documentation’. Since you simply don’t care acout correctness. It happens again and again and will never change.
oh the irony.“acout”
They don’t speak English, hence they make a lot of errors.
As with the R58, what is the reason for this, aside from a potentially higher clock speed which cannot be easily used, these chips are all the same?
What I miss in the video, something everybody else would do: Go to settings, scroll down, show which android version, which kernel.
and why didn’t he enter the PIN for the WiFi, does it not work?
android 5.1.1 version on it. and wifi , bt all working fine . all driver is working .
