Banana pi BPI-D1,use mobile to tontrol D1 ipcamera
(bpi team) #1
The BPI-D1 is the smallest open-source development board around, with a built-in HD mini camera. At 36mm (w) x36mm (l) and weighing in at 10g, it’s much smaller and lighter than any mini-cam or camera board out there. It allows you to create and customize your own mini-cam and can be a valuable part of any cool hardware you are working on. The D1 prides itself on providing high-resolution image quality: Both video and photos are captured at 1280x720p with a video capture rate of 30 fps. The BPI-D1 is designed specifically to give you all the multimedia tools you need in one small package. Simply connect to an external battery source (with your desired power capacity), and the D1 does the rest: there’s a HD mini-cam, audio sensor, microphone, CPU, GPIO, WiFi, and more - you name it, the D1 has it.
(zhiz z) #2
this looks so cool, must be fun to play with!
(Do Minh Quoc) #3
Can you share your documents or any codes? Thanks in advance
(Anna) #4
only missing things for me to buy it is WAN OPTION and ZOOM
