Banana pi bm2 berry wifi can't start
(r2d2) #1
Hi I’m a newbe on armbian (below my boot & some informations). I have install xfce and the image corresponding to my board (Armbian_5.83_Bananapim2ultra_Debian_stretch_dev_5.0.10) WIFI don’t runs (error below), i have tried commands/manipulations I read on forum/wiki/… Thank’s for help
login as: root
root@192.168.0.154's password:
 ____                                  ____  _   __  __ ____  _   _
| __ )  __ _ _ __   __ _ _ __   __ _  |  _ \(_) |  \/  |___ \| | | |
|  _ \ / _` | '_ \ / _` | '_ \ / _` | | |_) | | | |\/| | __) | | | |
| |_) | (_| | | | | (_| | | | | (_| | |  __/| | | |  | |/ __/| |_| |
|____/ \__,_|_| |_|\__,_|_| |_|\__,_| |_|   |_| |_|  |_|_____|\___/
Welcome to ARMBIAN 5.83 stable Debian GNU/Linux 9 (stretch) 5.0.10-sunxi
System load:   0.00 0.02 0.00   Up time:       1:04 hour                Local users:   3
Memory usage:  15 % of 1000MB   IP:            192.168.0.154
Usage of /:    17% of 7.2G
[ General system configuration (beta): armbian-config ]
Linux bpim2b 5.0.10-sunxi #5.83 SMP Mon Apr 29 08:07:24 CEST 2019 armv7l GNU/Linux
root@bpim2b:~# nmcli d
P▒RIPH▒RIQUE  TYPE      ▒TAT          CONNEXION
eth0          ethernet  connect▒      Wired connection 1
wlan0         wifi      indisponible  --
dummy0        dummy     non-g▒r▒      --
lo            loopback  non-g▒r▒      --
root@bpim2b:~# nmcli r
WIFI-HW  WIFI    WWAN-HW  WWAN
activ▒   activ▒  activ▒   activ▒
root@bpim2b:~# nmcli c
NOM                   UUID                                  TYPE             P▒RIPH▒RIQUE
Wired connection 1    bd8954ac-9686-39fa-8a8b-270c7d40545f  802-3-ethernet   eth0
Connexion Wi-Fi pipo  c572984a-ba6c-4cdb-a90b-0ec1be0a6726  802-11-wireless  --
root@bpim2b:~# nmcli n
activ▒
root@bpim2b:/etc/network# nmcli
eth0: connect▒ to Wired connection 1
        ethernet (dwmac-sun8i), 02:53:1A:D9:1B:5C, hw, mtu 1500
        ip4 default
        inet4 192.168.0.154/24
        route4 169.254.0.0/16
wlan0: indisponible
        "Broadcom "
        wifi (brcmfmac), B0:F1:EC:22:15:4C, hw, mtu 1500
dummy0: non-g▒r▒
        dummy, 26:6B:47:65:01:D1, sw, mtu 1500
lo: non-g▒r▒
        loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
DNS configuration:
        servers: 192.168.0.200
        interface: eth0
root@bpim2b:/etc/network# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.154  netmask 255.255.255.0  broadcast 192.168.0.255
        ether 02:53:1a:d9:1b:5c  txqueuelen 1000  (Ethernet)
        RX packets 13704  bytes 1297444 (1.2 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 10821  bytes 1356130 (1.2 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 35
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        loop  txqueuelen 1000  (Boucle locale)
        RX packets 3  bytes 204 (204.0 B)
        TX packets 3  bytes 204 (204.0 B)
root@bpim2b:/etc/network# iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
dummy0    no wireless extensions.
wlan0     IEEE 802.11  Mode:Master
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
root@bpim2b:~# hostapd -dd /etc/hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd.conf
ctrl_interface_group=0
nl80211: Using driver-based roaming
nl80211: TDLS supported
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Using driver-based off-channel TX
nl80211: Supported vendor command: vendor_id=0x1018 subcmd=1
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: use P2P_DEVICE support
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 4 iftype 3 (AP)
nl80211: Setup AP(wlan0) - device_ap_sme=1 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0x9286c0 (device SME)
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=0501
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=0503
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=0504
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=08
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x9286c0 match=7f
nl80211: Enable Probe Request reporting nl_preq=0x928720
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x928720 match=
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
Could not set interface wlan0 flags (UP): Input/output error
nl80211: Could not set interface 'wlan0' UP
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Disable Probe Request reporting nl_preq=0x881a0fa9
nl80211: Remove monitor interface: refcount=0
nl80211: Remove beacon (ifindex=4)
netlink: Operstate: ifindex=4 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211: Failed to set interface 4 to mode 2: -11 (Resource temporarily unavailable)
nl80211: Try mode change after setting interface down
nl80211: Failed to set interface up after switching mode
nl80211: Interface mode change to 2 from 3 failed
nl80211: Unsubscribe mgmt frames handle 0x881a0e49 (deinit)
nl80211 driver initialization failed.
hostapd_interface_deinit_free(0x9256e0)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0x9256e0)
wlan0: interface state UNINITIALIZED->DISABLED
hostapd_bss_deinit: deinit bss wlan0
wlan0: AP-DISABLED
hostapd_cleanup(hapd=0x926310 (wlan0))
wlan0: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlan0 wasn't started
hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit
hostapd_interface_free(0x9256e0)
hostapd_interface_free: free hapd 0x926310
hostapd_cleanup_iface(0x9256e0)
hostapd_cleanup_iface_partial(0x9256e0)
hostapd_cleanup_iface: free iface=0x9256e0
wlan0: AP-DISABLED
