topbot
(Robert)
Hi there,
I recently purchased your 4g module for the R2, got a 14 pin connector soldered in place but when I follow the direction in the Wiki
cd /sys/class/gpio/
echo 266 > export 【# 266(gpio_offset) = 232(base) + 34(GPIO_34)】
cd gpio266/
echo out > direction
echo 1 > value
it gives me the error “ash: write error: Resource busy” when I try to run the "echo 266 > export " command
Any help would be appreciated!
frank-w
(Frank W.)
2
Maybe 266 is already exported…make a ls in /sys/class/gpio and look if folder of your gpio exists
topbot
(Robert)
3
I checked, no folder exists yet.
I am using openwrt/lede that I built using the instructions on the wiki
frank-w
(Frank W.)
4
You do the echo as root? which kernelversion?
some things in lede are different as on debian/ubuntu. Have you checked base is same as in my code? And gpio 34 is right
topbot
(Robert)
5
I am using this repo
https://github.com/garywangcn/bpi-r2_lede/tree/bpi-r2-on-lede-v1
Kernel version 4.9.44
How do I check if gpio is right?
