Just got my banana pi R2 and 4g module, went to connect the 4g module to the board via 14 pin header but both sides are female. What extra connector do I need to use the 14 pin header connection?
You could just solder some header pins to the pads. Or if you want to take it off in the future you can try to solder some nice connectors on the boards. No specialised connectors required.
Connector:
Thanks!
Where can I get one of these?
