Banana BPI:bit wifi
(Tezenas Du Montcel) #1
Hello,
Is it possible to programme your bpi bit webduino via Python or micropython with Mu IDE for exemple? Do you have a example of programme? Thanks to help me. Your sincerely.
Julien
(bpi team) #2
yes, you can see our wiki online documents:
http://wiki.banana-pi.org/BPI:bit_for_MicroPython
(Tezenas Du Montcel) #3
Hello,
Very thanks to answer. I already use the microbit card with the Mu editor which is perfect with autocompletion. Very practical for development. I saw that you propose a tool too basic to program your map in Python with the file windows-mpfshell.exe. It is a tool that allows to communicate with the python interpreter on the Microbit card? is it this. If so, then the tool is unusable to properly perform program and be used in teaching. Could you add your bit-beep card to the IDE Mu? Would you otherwise have a development tool (IDE) worthy of the name? Would it be possible to have all the APIs in one clean and well-informed document like on the Microbit website here: https://microbit-micropython.readthedocs.io/en/latest/tutorials/introduction.html Thank you for your very specific answers. Your sincerely.
Julien
(bpi team) #4
this wiki for chinese , it is any help for you???
(Juwan) #5
HI~
If you need a micropython development tool.
  1. mpfshell.exe
too simple !
  1. pycharm for mpfshell.
http://wiki.banana-pi.org/4_Pycharm_IDE_programming
too professional !
  1. thonny support micropython
https://thonny.org/
better than mu-editor ~!
Your choice~
But Scratch3 and blockly support mpfshell in the future.
So stay tuned~
(Tezenas Du Montcel) #6
Hello,
Thank you for your answers. Your mpfshell.exe software is not suitable for programming at all, since you have to type all the codes one after the other. This tool is used only for simple tests. Could you tell me how to upload a python program into your bit-bip map with thonny. No explanation on the site thonny. Thonny is a very good IDE too. Pyscharm is the top, but more complicated to use for students and more difficult to install. You allow yourself to judge the IDE Mu too quickly. Indeed, it has the advantage of being very simple with all the basic functions for teaching. It lacks the mode of debugging and visualization of variable. But you can draw graphique, use REPL mode and very easy to use with autocompletion. Do you have a python simulator for the bit_bip map like the one on the microbit map here? https://create.withcode.uk/ Thank you for your help. your sincerely. Julien
(Tezenas Du Montcel) #7
Hello, Would you have a website that gives all the information on the functions and commands in micropython to drive your Bit-bip card especially on the new features compared to the microbit card, such as color management, gyroscope, wifi, bluetooth. Indeed, the microbit card does not manage the bluetooth micropython because its 16K RAM is too low for the Bluetooth stack. Thank you for your clarification and links to your specific explanatory documents. https://microbit-micropython.readthedocs.io/en/latest/tutorials/introduction.html Your sincerely. Julien
(Juwan) #9
english wiki :
about wifi wireless:
http://wiki.banana-pi.org/2_WiFI_wireless_connection
http://wiki.banana-pi.org/3_WiFI_wireless_programming
(Juwan) #10
Well, for mu editor, I also provide the corresponding espblock, and support blockly and microbit simulation, because mu editor does not support micropython native, and for me there is no blockly, so I think espblock may be more in line with your meaning.
See this https://github.com/BPI-STEAM/BPI-BIT-MicroPython/wiki/espblock
(Tezenas Du Montcel) #11
Hello,
I have seen your documents, but none of them shows how to program a very simple micropython application on your card bit-bip to fix whether the card is in access point or client mode. How to fix its IP address and subnet mask. how then send (TCP) a single byte to a recipient (IP address), or broadcast in UDP. How to receive a byte in TCP or UDP. Could you send me a python program example to set IP address and send and receive one byte under TCP and UDP protocol for exemple. In short, a lot of information is still missing. Could you group at a given address all micropython commands, because I would not want to ask you without stopping where is this or that command. Propose a global menu by theme as you see it on this site very well done and very clear, it lacks nothing. I’m talking about the map bit-bip not the banana Pi! This link no nowhere, with no information!?? https://github.com/BPI-STEAM/BPI-BIT-MicroPython/wiki/espblock How use Mu with your bit-bip? same question, but no answer from you with thonny IDE?? thanks to be very precise and help me to program your bit-bip in micropython. Thanks to answer. Your sincerely. Julien
(Juwan) #12
Oh, sorry, about the core of the wifi interface, you need to look at the http://docs.micropython.org/en/latest/esp8266/tutorial/network_basics.html? Highlight = ifconfig
Part about the wifi code, can refer to the https://github.com/BPI-STEAM/BPI-BIT-MicroPython/tree/master/12.network
Or is the https://github.com/micropython/micropython/tree/master/examples/network
(Tezenas Du Montcel) #13
Hello, Could you ask your engineers to give me a simple example in MicroPython to send and receive a simple byte between two bit cards: beep in wifi. Many thanks for your very specific help. Your sincerely.
Julien
(Juwan) #14
well, in http://docs.micropython.org/en/latest/esp8266/tutorial/network_tcp.html
attention HTTP is TCP on port 80
(Tezenas Du Montcel) #15
Hello,
do you have command to set the bit/bip in access point, and not in station mode in wifi? Thanks to be very precise. Julien
