I know this topic should go to armbian forums (I posted it already) but maybe someone of you will suggest me something. It’s strange becouse It was most complete OS for BPI R2. The problem is: I try to run this image: Armbian_20.02.0-rc0_Bananapir2_buster_legacy_4.19.97_minimal.img on Sinovoip Banana PI R2 (from SD card) and on 1-st boot i’m stuck: Tx DQM dly bit4 = 0x0 DRAMC_DQODLY1=79A98889h DRAMC_DQODLY2=8988B99Ah DRAMC_DQODLY3=2203123h DRAMC_DQODLY4=31103014h Tx DQ dly bit4 = 0x0 Tx DQS dly = 0x8949 Tx DQS dly bit4 = 0x0 TX Byte0: DQ - 16, DQS - 17. win_sum= 32 TX Byte1: DQ - 21, DQS - 13. win_sum= 33 TX Byte2: DQ - 8, DQS - 22. win_sum= 29 TX Byte3: DQ - 8, DQS - 22. win_sum= 29 DRAMC calibration takes 651397386 CPU cycles
[EMI] DRAMC calibration passed
[MEM] complex R/W mem test pass
0:dram_rank_size:80000000
[Dram_Buffer] dram size:-2147483648
[Dram_Buffer] structure size: 1725560
[Dram_Buffer] MAX_TEE_DRAM_SIZE: 0
Boot from SD Card!!
[PLFM] Init Boot Device: OK(0)
[PART] blksz: 512B
[PART] [0x0000000000000000-0x000000000003FFFF] "PRELOADER" (512 blocks)
B[TOOL] <UART> listen ended, receive size:3!
[TOOL] <UART> wait sync time 150ms->5ms
[TOOL] <UART> receieved data: ()
Device APC domain init setup:
bootloader load uboot ,the address of uboot is 81E00000
[PART]partition name UBOOT
[PART]partition start block 0x200
[PART]partition size 0x80000
[PART]partition blks 0x400
[PART]partition flags 0x0
[PART]partition name 0x8
[bean] part->startblk(0x200) bdev->blksz(0x200) part->part_id(8) hdr(0xFFB50000)
[BlkDev.c 101 ]partition block size 0x200 ,blks:0xECE000
[BlkDev.c 101 ]partition block erase size 0x200
[PART] load "UBOOT" from 0x0000000000050000 (dev) to 0x81E00000 (mem) [SUCCESS]
[PART] load speed: 5978KB/s, 300000 bytes, 49ms
[BT_SD_PG] device info 0x8590 0x8A00 0xCB01 0x102
[PLFM] md_type[0] = 255
[PLFM] md_type[1] = 255
[PLFM] boot reason: 0
[PLFM] boot mode: 0
[PLFM] META COM0: 0
[PLFM] <0xFFB7CC10>: 0x0
[PLFM] boot time: 1906ms
[PLFM] DDR reserve mode: enable = 0, success = 0
[BLDR] jump to 0x81E00000
[BLDR] <0x81E00000>=0xEA0000B8
[BLDR] <0x81E00004>=0xE59FF014
[USBD] USB PRB0 LineState: 0
[USBD] USB cable/ No Cable inserted!
[PLFM] Keep stay in USB Mode
Platform initialization is ok
wait for frequency meter finish, CLK26CALI = 0x81
mt_pll_post_init: mt_get_cpu_freq = 1040000Khz
wait for frequency meter finish, CLK26CALI = 0x90
mt_pll_post_init: mt_get_bus_freq = 273000Khz
mt_pll_post_init: mt_get_mem_freq = 133250Khz
[PWRAP] pwrap_init_preloader
[PWRAP] pwrap_init
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=0,rdata=2D52
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=1,rdata=2D52
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=2,rdata=2D52
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=3,rdata=800
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=4 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=5 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=6 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=7 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=8 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=9 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=10 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=11,rdata=1001
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=12,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=13,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=14,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=15,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=16,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=17,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=18,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=19,rdata=2003
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=20,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=21,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=22,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=23,rdata=6A97
[PWRAP] _pwrap_init_reg_clock
[PMIC_WRAP]wrap_init pass,the return value=0.
[pmic6323_init] Preloader Start..................
[pmic6323_init] PMIC CHIP Code = 0x2023
INT_MISC_CON: 1 TOP_RST_MISC: 1
pl pmic powerkey Release
[pmic6323_init] powerKey = 0
[pmic6323_init] is USB in = 0xB004
[pmic6323_init] Reg[0x11A]=0x1B
pmic setup LED
[pmic6323_init] Done...................
mt7623 disable long press reset ->>>>>
mt7623 disable long press reset <<<<<-
mt7623 VPA supplied by 1.0V to MT7530 ->
mt7623 VPA supplied by 1.0V to MT7530 <-
mt7623 enables RG_VGP1_EN for LCM ->
mt7623 enables RG_VGP1_EN for LCM <-
MT7623 E2 setting =>
MT7623 E2 setting <=
[PLFM] Init I2C: OK(0)
[PLFM] Init PWRAP: OK(0)
[PLFM] Init PMIC: OK(0)
[PLFM] chip[CA00]
[BLDR] [Support SD/eMMC] Build Time: 20170114-170026
==== Dump RGU Reg ========
RGU MODE: 4D
RGU LENGTH: FFE0
RGU STA: 0
RGU INTERVAL: FFF
RGU SWSYSRST: 0
==== Dump RGU Reg End ====
RGU: g_rgu_satus:0
mtk_wdt_mode_config mode value=10, tmp:22000010
PL P ON
WDT does not trigger reboot
RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3)
kpd read addr: 0x0040: data:0x4001
Enter mtk_kpd_gpio_set!
kpd debug column : 0, 0, 0, 0, 0, 0, 0, 0
kpd debug row : 0, 0, 0, 0, 0, 0, 0, 0
after set KP enable: KP_SEL = 0x0 !
MTK_PMIC_RST_KEY is used for this project!
[RTC] get_frequency_meter: input=0x0, ouput=5
[RTC] get_frequency_meter: input=0x0, ouput=3967
[RTC] get_frequency_meter: input=0x0, ouput=0
[RTC] bbpu = 0xD, con = 0x426
[RTC] powerkey1 = 0xA357, powerkey2 = 0x67D2
Writeif_unlock
[RTC] RTC_SPAR0=0x40
rtc_2sec_reboot_check cali=1792
rtc_2sec_stat_clear
[RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0x40, spar1 = 0x800
[RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1
[RTC] bbpu = 0xD, con = 0x426, cali = 0x700
[PLFM] Power key boot!
[RTC] rtc_bbpu_power_on done
[EMI] mcp_dram_num:0,discrete_dram_num:1,enable_combo_dis:0
[EMI] PCDDR3
[Check]mt_get_mdl_number 0x0
[EMI] eMMC/NAND ID = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[EMI] MDL number = 0
[EMI] emi_set eMMC/NAND ID = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[EMI][Vcore]0x21E=0x48,0x220=0x48
[EMI][Vmem]0x554=0x0
[EMI] PCDDR3 DRAM Clock = 1600012 KHz, MEMPLL MODE = 2
[EMI] PCDDR3 RXTDN Calibration:
Start REXTDN SW calibration...
drvp=0xB,drvn=0x9
[EMI] pinmux = 4
dramc_write_leveling_swcal
delay byte0 byte1 byte2 byte3
0 0 0 0 1
1 0 0 0 1
2 0 0 1 1
3 0 0 1 1
4 0 1 1 1
5 0 1 1 1
6 0 1 1 1
7 0 1 1 1
8 0 1 1 1
9 1 1 1 1
10 1 1 1 1
11 1 1 1 1
12 1 1 1 1
13 1 1 1 1
14 1 1 1 1
15 1 1 1 1
pass bytecount = 4
byte_i status best delay
0 2 9
1 2 4
2 2 2
3 2 0
[write leveling]DQS: 0x249, DQM: 0x249
[write leveling after remap]DQ byte0 reg: 0x200 val: 0x99994444
[write leveling after remap]DQ byte1 reg: 0x204 val: 0x44449999
[write leveling after remap]DQ byte2 reg: 0x208 val: 0x22220000
[write leveling after remap]DQ byte3 reg: 0x20C val: 0x2222
X-axis: DQS Gating Window Delay (Fine Scale)
Y-axis: DQS Gating Window Delay (Coarse Scale)
0 8 16 24 32 40 48 56 64 72 80 88 96 104 112 120
0000:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0001:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0002:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0003:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0004:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0005:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0006:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0007:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0008:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0009:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000A:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000B:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000C:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000D:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000E:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000F:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0010:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1
0011:| 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1
0012:| 0 0 0 1 1 1 1 1 1 1 1 1 1 1 0 0
0013:| 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0
0014:| 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0015:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0016:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0017:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0018:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0019:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001A:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001B:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001C:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001D:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001E:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
001F:| 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Rank 0 coarse tune value selection : 18, 18
18
64
rank 0 coarse = 18
rank 0 fine = 64
00:| 0 0 0 0 0 0 0 0 1 1 1 0
opt_dle value:13
RX DQS perbit delay software calibration
1.0-31 bit dq delay value
bit| 0 1 2 3 4 5 6 7 8 9
0 | 0 0 0 0 0 0 0 0 0 0
10 | 0 0 0 0 0 0 0 0 0 0
20 | 0 0 0 0 0 0 0 0 0 0
30 | 0 0
2.dqs window
x=pass dqs delay value (min~max)center
y=0-7bit DQ of every group
input delay:DQS0 =50 DQS1 = 40 DQS2 =53 DQS3 = 44
bit DQS0 bit DQS1 bit DQS2 bit DQS3
0 (19~69)44 8 (5~58)31 16 (23~69)46 24 (15~58)36
1 (19~70)44 9 (7~60)33 17 (22~70)46 25 (15~60)37
2 (21~70)45 10 (9~62)35 18 (25~70)47 26 (17~63)40
3 (18~68)43 11 (11~61)36 19 (21~68)44 27 (17~63)40
4 (21~77)49 12 (17~62)39 20 (27~79)53 28 (21~68)44
5 (21~68)44 13 (15~61)38 21 (25~71)48 29 (18~61)39
6 (21~69)45 14 (13~60)36 22 (25~72)48 30 (16~62)39
7 (25~76)50 15 (16~64)40 23 (31~74)52 31 (18~64)41
3.dq delay value last
0 | 6 6 5 7 1 6 5 0 9 7
10 | 5 4 1 2 4 0 7 7 6 9
20 | 0 5 5 1 8 7 4 4 0 5
30 | 5 3
*DQIDLY1 = 0x7050606
*DQIDLY2 = 0x50601
*DQIDLY3 = 0x4050709
*DQIDLY4 = 0x40201
*DQIDLY5 = 0x9060707
*DQIDLY6 = 0x1050500
*DQIDLY7 = 0x4040708
*DQIDLY8 = 0x3050500
*DRAMC_R0DELDLY = 0x2C352832
[MEM]CONA:F3A2,conf1:F07486A3
DM4BitMux = 1
DQSO 0 in TX per-bit = 2 <= DQSO 0 in WL = 9
DQSO 1 in TX per-bit = 0 <= DQSO 1 in WL = 4
[Warning] DQSO 2 in TX per-bit = 9 > DQSO 2 in WL = 2
[Warning] DQSO 3 in TX per-bit = 8 > DQSO 3 in WL = 0
Tx DQM dly = 0x1189
DRAMC_DQODLY1=79A98989h
DRAMC_DQODLY2=8988B99Bh
DRAMC_DQODLY3=2103123h
Tx DQS dly = 0x8949
DRAMC calibration takes 651397844 CPU cycles
Boot from SD Card!!
[PART] blksz: 512B
[PART] [0x0000000000000000-0x000000000003FFFF] "MBR" (512 blocks)
[PART] [0x0000000000040000-0x00000000000BFFFF] "UBOOT" (1024 blocks)
[PART] [0x00000000000C0000-0x00000000000FFFFF] "CONFIG" (512 blocks)
[PART] [0x0000000000100000-0x000000000013FFFF] "FACTORY" (512 blocks)
[PART] [0x0000000000140000-0x000000000213FFFF] "BOOTIMG" (65536 blocks)
[PART] [0x0000000002140000-0x000000000413FFFF] "RECOVERY" (65536 blocks)
[PART] [0x0000000004140000-0x000000004413FFFF] "ROOTFS" (2097152 blocks)
[PART] [0x0000000044140000-0x000001FFC413FFFF] "USER" (-4194304 blocks)
[platform_vusb_on] PASS
[TOOL] PMIC not dectect usb cable!
[TOOL] <UART> listen ended, receive size:0!
[PLFM] boot mode: 0
[PLFM] META COM0: 0
[PLFM] boot time: 1901ms
checked all builds:
up to 5.75 works perfectly; after no one boot; all stuck on same message;
any help will appreciated.
