I installed the image Armbian_5.41_Bananapim64_Ubuntu_xenial_next_4.14.18_desktop.img on eMMC. Then I updated the OS via: apt-get update & upgrade. The device then booted and got stuck at Armbian logo with the following error message at the bottom of the screen:
"Unable to handle kernel paging request at virtual address fff00000fff00"
The image Armbian_5.41_Bananapim64_Ubuntu_xenial_next_4.14.18 does work. The problem is after running apt-get update & upgrade. Maybe my bpi m64 has a RAM memory issue? Is there a way to check it? Thanks.
I just downloaded Armbian_5.69_Bananapim64_Debian_stretch_next_4.19.13.img from the link you provided and burned on a SD. My BPI M64 freezes while loading the OS on the Armbian Logo. I tried with different SD cards and the same issue happened. I also tried with Armbian Bionic but the system freezes as well.
The images Armbian_5.41_Bananapim64_Ubuntu_xenial_next_4.14.18_desktop.img and Armbian_5.41_Bananapim64_Debian_stretch_next_4.14.18_desktop.img works fine. The problem is when I upgrade the system. I believe this is a bug.
I test the exact image - can’t reproduce. At least not with my Banana and my pitch perfect lab cabling/PSU.
http://ix.io/1yuA
and after update
http://ix.io/1yuB
Start here to rule out basic problems.
https://docs.armbian.com/User-Guide_Getting-Started/
It can be more sinister like your memory is border quality. Diagnostic such problems is hard if you are alone and if you only have one board … which works.
Thanks for your support but nothings seems to work for me. Below is what I did and whats going on:
BPI M64, SD Card class 10, PSU 5V 2A
Armbian_5.41_Bananapim64_Ubuntu_xenial_next_4.14.18_desktop.img works fine
3.Armbian_5.69_Bananapim64_Ubuntu_bionic_next_4.19.13_desktop.img does not work. It freezes when loading the system no matter if burned on eMMC or SDcard.
OBS: I erased eMMC with /dev/zero. I tried with armbian-config in order to burn the image to eMMC and also doing dd from CLI. Both methods did not work.
Unfortunately I will most probably have to wait for a newer version of this great OS.
Just to update this thread. I installed Armbian 5.65 Ubuntu bionic 18.04 kernel 4.14.78-sunix 64. Everything works fine if I do not update the following kernel related packages:
Confirm this issue (i.e. unable to install debian buster due kernel crash occured).
Issue located at linux-dtb-next-sunix64 package.
Temporary solution:
install debian stretch;
hold working package and update stretch to last release by following commands:
apt-mark hold linux-dtb-next-sunxi64
apt-get update
apt-get --autoremove dist-upgrade
reboot computer
edit files /etc/apt/sources.list and /etc/apt/sources.list.d/armbian.list (replace all “stretch” to “buster”)
perform standard upgrade procedure by following commands:
apt-get update
