Archlinux on R2
Oh yes. So should i create uEnv.txt file with this? systemd.unit=rescue.target
I think you can also enter u-boot cli mode and run setenv bootargs kernel option. Replace kernel option with that line.
My uboot runs this to build bootargs…
Just add this to your uenv.txt (overwriting my bootargs so add its previous content):
bootopts=vmalloc=496M debug=7 initcall_debug=0 systemd.unit=rescue.target
have you Cli-access with debuguart?
@spikerguy I might have a look today or tommorrow why the logind service is failing if you want to share the Archlinux R2 image.
Sure. Let me make a flashable R2 ready image for you.
Yes.
Then you can see uboots menu and choose uboot-console to look if your uenv.txt is read.
Sure. I will test this tonight. As in the log It shows Line 406, as it searches for uEnv.txt file.
Thanks. Will get back to you after trying it.
you use old/official uboot? this only loads uenv.txt on selecting the “boot from sd”-entry, not before display the menu
but for testing your case it will be enough
I am using your 1m boot file with your 4.19 kernel boot partition.
I tried this but no luck.
Here is the UART log.
If we read the log, I tried to login with alarm/alarm as well as root/root but Its always Authentication Failure.
mhm, afair 1M-file from my wiki/gdrive was created before uboot upstream support
Should I use the 2019 1M file which I have extracted from your latest built? Will that make any difference?
it has at least redesigned buildin-environment where we can do some things easier in uboot-console
e.g. “run buildargs” manually and see if your option is now in bootargs (printenv bootargs)
I flashed the 2019 1M and that seems to accept the bootarg allowed to login in Rescue mode.
Now I will try to remove the uEnv.txt and try again. Thank You very much. Ah but again It doesnt let me login withlogin password. I am not able to login in rescue mode. @cioby23
Here is the journal log from rescue mode.
Sep 23 23:54:31 alarm systemd-tmpfiles[191]: Failed to open directory 'private'>
Sep 23 23:54:31 alarm systemd-tmpfiles[191]: Failed to create file /var/log/wtm>
Sep 23 23:54:31 alarm systemd-tmpfiles[191]: Failed to create file /var/log/btm>
Sep 23 23:54:31 alarm systemd-tmpfiles[191]: Failed to create file /var/log/las>
looks wrong
what is output of
"systemctl status systemd-logind.service" and "journalctl -xe"
* systemd-logind.service - Login Service
   Loaded: loaded (/usr/lib/systemd/system/systemd-logind.service; static; vend>
   Active: inactive (dead)
     Docs: man:systemd-logind.service(8)
           man:logind.conf(5)
           https://www.freedesktop.org/wiki/Software/systemd/logind
           https://www.freedesktop.org/wiki/Software/systemd/multiseat```
[quote="frank-w, post:35, topic:3986"]
"journalctl -xe"
[/quote]
    journalctl -xe
    Sep 23 23:54:33 alarm systemd[1]: systemd-timesyncd.service: Start request repe>
    Sep 23 23:54:33 alarm systemd[1]: systemd-timesyncd.service: Failed with result>
    -- Subject: Unit failed
    -- Defined-By: systemd
    -- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
    -- The unit systemd-timesyncd.service has entered the 'failed' state with resul>
    Sep 23 23:54:33 alarm systemd[1]: Failed to start Network Time Synchronization.
    -- Subject: A start job for unit systemd-timesyncd.service has failed
    -- A start job for unit systemd-timesyncd.service has finished with a failure.
    -- The job identifier is 107 and the job result is failed.
    Sep 23 23:54:33 alarm systemd[209]: rescue.service: Executable /bin/plymouth mi>
    -- Subject: Process /bin/plymouth could not be executed
    -- The process /bin/plymouth could not be executed and failed.
    -- The error number returned by this process is ERRNO.
not more? maybe you have to scroll…
I tried to restart the service so I can get logind error.
journalctl -xe
Sep 24 00:08:15 alarm systemd[1]: Failed to start Login Service.
-- Subject: A start job for unit systemd-logind.service has failed
-- A start job for unit systemd-logind.service has finished with a failure.
-- The job identifier is 395 and the job result is failed.
Sep 24 00:08:23 alarm systemd[1]: systemd-logind.service: Start request repeate>
Sep 24 00:08:23 alarm systemd[1]: systemd-logind.service: Failed with result 'r>
-- The unit systemd-logind.service has entered the 'failed' state with result '>
Sep 24 00:08:23 alarm systemd[1]: Failed to start Login Service.
-- The job identifier is 451 and the job result is failed.
scroll a bit to right…it’s cut off
result is done.
d-logind.service: Start request repeated too quickly.
d-logind.service: Failed with result 'resources'.
ntered the 'failed' state with result 'resources'.
I see this also in journal -xe
-logind.service: Failed to run 'start-pre' task: Read-only file system
