Android Mattrix XBMC/KODI Image - V3.1
share by mattrix
It’s been a long time coming, but I finally got around to creating a new XBMC Image
Here are the main features:
  • Latest KODI 14.0
  • Auto-setup of KODI, MX Player & SMB Wrapper
  • Autostart KODI on boot
  • SMB Wrapper to allow playback of Network files
  • 720p & 1080p Versions Available
  • HIDRaw and Joystick Drivers + XPAD module loaded on boot
Both images playback videos fine, but the 720p image is quite a bit faster in the GUI. The latest KODI is now capable of playing back most videos I tried natively. However, it is still using quite a bit of CPU and may not playback everything. I therefore decided to use MX Player for playback for a more consistent user experience.
V3.1 720p (297 MB) Mega 1080p (297 MB) Mega
INSTRUCTIONS:
  • Unzip image & burn with PhoenixCard
  • Boot, and then wait… (about 1-2 mins)
  • KODI will automatically start (signalling the end of the installation process)
  • That’s it.
  • If using 1080p version, exit KODI and set 1080P in Android Display settings
KODI is setup to use SMB Wrapper / MX Player for network files and to use MX Player for any local files. You can easily edit or remove the playercorefactory.xml file in sdcard/Android/data/org.xbmc.kodi/files/.kodi/userdata folder. To disable KODI autostart, remove sdcard/Android/data/mattrix/autostartkodi
Here are the changes:
Changes 02/01/2015 (3.1):
  • Updated to Kodi 14.0
  • Replace XBMC Wrapper with SMB Wrapper
Changes 13/11/2014 (3.0):
  • Update XBMC to latest Kodi
  • Remove “allow unverified apps” popup on boot
  • Add HDIRaw and Joystick drivers
  • Load xpad module on boot
  • Fix “Mobile Networks” settings option doesn’t work
Changes 11/11/2014 (2.0):
  • Latest 3.4.39 Kernel
  • Automated setup on first boot (no copying / pasting needed - just ready to roll)
  • Autoboot into XBMC
  • Added XBMC Wrapper App to wrap network files as HTTP streams
  • Removed SuperSu App (this can be added via Playstore if required)
  • Set CPU frequency settings on boot
Changes (Initial Release - 1.0):
  • Rooted
  • SD Card Storage Mount Fix
  • Set to stock Android Launcher
  • Ethernet Default to ON
  • Remove all apps (can be added back via PlayStore if required)
  • Add XBMC App
  • Add MX Player
  • Add SuperSu App
Give it a go and let me know any suggestions / problems!
This looks promising http://forum.kodi.tv/showthread.php?tid=155526&page=2
Thanks,
Matt
I need the Android Mattrix XBMC/KODI Image - V3.1 1080p please. The link: https://mega.nz/#!WIhUSJZA!RfpRGGHn6L0HQF2gdDlYqQtOs-DwVNLBVVrQxltqJGw not fund
UP ! Please can you provide the link MEGA again :slight_smile: The link: https://mega.nz/#!WIhUSJZA!RfpRGGHn6L0HQF2gdDlYqQtOs-DwVNLBVVrQxltqJGw not fund
Can someone please re-upload this xbmc/kodi image?
