7 inch Screen is not working on Android
(Essam Salah) #1
Hey folks,
I thought to share the problem I am having here, may be some could help me out …
I got the BPI-M2M and the BPI 7 inch touch screen, my BPI-M2M is connected to my mac via USB2UART dongle, burned Android on SD Card and the board have booted but the screen is not working.
Here is the boot log as it appear on my terminal:
127|shell@bpi-m2m:/ $ [    0.658924] failed to get normal led pin assign
[    0.659033] failed to get standby led pin assign
[    0.829455] WRN:L486(drivers/usb/sunxi_usb/hcd/hcd0/sunxi_hcd0.c):get no_suspend status failed
[    0.861980] sunxi_oops: heming add OOPS_INFO_ADDR = -20
[    0.869286] [audiocodec] : aif2 not used!
[    0.873840] [audiocodec] : aif3 not used!
[    0.884116] [I2S0]sunxi-i2s0 cannot find any using configuration for controllers, return directly!
[    0.894480] [I2S]sndi2s0 cannot find any using configuration for controllers, return directly!
[    0.904214] [I2S1]sunxi-i2s1 cannot find any using configuration for controllers, return directly!
[    0.914554] [I2S]sndi2s1 cannot find any using configuration for controllers, return directly!
[    0.932538] otg_wakelock_init: No USB transceiver found
[    0.938569] ths_fetch_sysconfig_para: type err  device_used = 1.
[    0.945428] ths_fetch_sysconfig_para: type err ths_trip1_3 = 110.
[    0.952442] ths_fetch_sysconfig_para: type err ths_trip1_4 = 110.
[    0.959373] ths_fetch_sysconfig_para: type err ths_trip1_5 = 110.
[    0.966388] ths_fetch_sysconfig_para: type err ths_trip1_6 = 110.
[    0.973405] ths_fetch_sysconfig_para: type err ths_trip1_7 = 110.
[    0.980365] ths_fetch_sysconfig_para: type err ths_trip1_3_min = 0.
[    0.987563] ths_fetch_sysconfig_para: type err ths_trip1_3_max = 0.
[    0.994706] ths_fetch_sysconfig_para: type err ths_trip1_4_min = 0.
[    1.001925] ths_fetch_sysconfig_para: type err ths_trip1_4_max = 0.
[    1.009049] ths_fetch_sysconfig_para: type err ths_trip1_5_min = 0.
[    1.016346] ths_fetch_sysconfig_para: type err ths_trip1_5_max = 0.
[    1.023491] ths_fetch_sysconfig_para: type err ths_trip1_6_min = 0.
[    1.030701] ths_fetch_sysconfig_para: type err ths_trip1_6_max = 0.
[    1.037901] ths_fetch_sysconfig_para: type err ths_trip2_count = 0.
[    1.045043] ths_fetch_sysconfig_para: type err ths_trip2_0 = 0.
[    1.512496] init: waitpid failed: No child processes
[    1.521787] init: /init.sun8i.rc: 119: invalid command 'setenforce'
[    1.531118] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    2.027540] init: /dev/hw_random not found
[    2.244841] init: /dev/hw_random not found
[    4.381157] FAT-fs (mmcblk0p16): bogus number of reserved sectors
[    5.013097] sunxikbd_script_init: key para not found, used default para.
[    5.047688] ctp_fetch_sysconfig_para: ctp_power_io script_get_item err.
[    5.055559] ctp_irq gpio number is 37
[    5.360456] WRN:L486(drivers/usb/sunxi_usb/hcd/hcd0/sunxi_hcd0.c):get no_suspend status failed
[    6.172472] init: /recovery not specified in fstab
[    6.177950] init: void property_opt_for_mem(): start!
[    6.184958] init: bool get_lcd_resolution(int *, int *): ro.boot.lcd_x not set, disable adaptive memory function!
[    6.196566] init: void property_opt_for_mem(): get lcd resolution failed!
[    6.544134] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
[    6.566395] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
shell@bpi-m2m:/ $ [    7.007918] android_usb: already disabled
