4OZ Heavy Copper 4L PCB with ENIG
4OZ%20Heavy%20Copper%204L%20PCB%20with%20ENIG
PRODUCT DESCRIPTION
Base Material Fr4 TG170
Layer Counts 4L
Board Thickness 2.0mm
Copper Thickness 4OZ
Min.Hole Size 12mil(0.3mm)
Min.Line Width/Spacing 8mil(0.2mm)/10mil(0.25mm)
Solder maks Color Green
Silkscreen Color None
Surface Finishing ENIG
Min.Quantity of Order No MOQ
Certificat UL,ISO 9001,ISO 14001
Difficulty Heavy Copper
Processing capability
Base material: FR4/Aluminum
Copper thickness: 4 OZ~6OZ
Outline: Routing, punching, V-Cut
Soldermask: White/Black/Blue/Green/Red Oil
Surface finishing: Immersion Gold, HASL, OSP
Typical conductor width/spacing/thickness tolerance is +/-20%, although tighter tolerance is achievable.
Applications for Heavy Copper
Heavy copper can be used for a variety of purposes, including, but not limited to, high power distribution, High current applications, thermal distribution for good thermal management, planar transformers, and power convertors.
