2.4Ghz and 5.6Ghz Wifi Working fine
(sunarowicz) #41
I discovered the same behaviour with LAN interface as well. Everytime I boot R2 up it has different MAC on LAN interface it is connected to network and obtains different IP from DHCP. Setting the static MAC in NetworkManager doesn’t help.
(Frank W.) #42
for LAN-Interfaces there is a fix using /etc/network/interfaces:
hwaddress ether ...
(Paweł Kalemba) #43
It Will be suported on LEDE?
(Frank W.) #44
i’m sure it will be ported to lede-kernel to (and hopefully to 4.14) if it’s working correctly
the existing issues (random mac-Adress which resulting different devices by udev, 2 wlan-devices for 1 physical [client vs ap]) must be fixed first and then the device must be detected without starting anything or any echo…it’s ok during wifi-debugging, but not for stable usage
home-routerboard without wlan-AP is quite useless
(Benoit) #45
Hello do you have some news for Ap-Mode on Ubuntu? Do you plan a new ubuntu image with APMode and Vlan/switch mode?
#46
Hi @garywang , once I enable the driver (using init.d and doing echo A to enable AP too), I get the following log in dmesg, any idea? I think wifi crashes the kernel at some point, for example I had to reboot the board after hours because I was not able to login to it via SSH anymore and the board was offline (the bridge was working but the OS wasn’t). I only noticed following logs so ATM I’m testing without enabling MT6625. I’m using latest Ubuntu kernel (commit 81d24bb)
[   19.107464] 0x01 0x01 0xe9 0x03 0x02 0xdd 0x3c 0x3e 0x00 0x6c 0x34 0xd5 0x17 0x2f 0xe0 0x6c 0x02 0x01 0x01 0x00 0x00 0x01 0x01 0xe9 0x03 0x02 0x4c 0x02 0xc1 0x78 0x48 0x00 0x01 0x7c 0x46 0x08 0x11 0x02 0x01 0x01 0x00 0x00 0x01 0x01 0xe9 0x03 0x02 0xd5 0x0c 0x84 0x0c 0xd5 0x08 0x49 0xfe 0x24 0x23 0x84 0x02 0x01 0x01 0x00 0x00 0x01 0x01 0xe9 0x03 0x02 0x49 0xfe 0x45 0x70 0xec 0x04 0x3a 0x6f 0xa4 0x84 0xdd 0x02 0x01 0x01 0x00 0x00 0x01 0x01 0xe9 0x03 0x02 0x4e 0x82 0x00 0x0d 0x3c 0x1c 0x07 0x7f 0x84 0x02 0xdd 0x02 0x01 0x01 0x00 0x00 0x01 0x01 0x35 0x00 0x03 0xd4 0xef 0x06 0x00 0x08 0x00 0x00 0x00 0x02 0x00 0x00 0x02 0x01 0x01 0x00 0x00 0x01 0x07 0x01 0x00 0x04 0x02 0x07 0x01 0x00 0x00 0x01 0x08 0x10 0x00 0x01 0x01 0x00 0x01 0x0c 0x01 0x00 0x80 0x00 0x4d 0x84 0x00 0x02 0x08 0x04 0x00 0x00 0x00 0x00
[   19.107728] 0x01 0x01 0x08 0x10 0x00 0x01 0x01 0x00 0x01 0x34 0x03 0x00 0x80 0x00 0x00 0x00 0x00 0x02 0x08 0x04 0x00 0x00 0x00 0x00 0x01 0x01 0x14 0x01 0x00 0x01 0x02 0x14 0x72 0x02 0x00 0x01 0x01 0x11 0x11 0x4d 0x4d 0x4c 0x4c 0x4b 0x4b 0x4a 0x01 0x10 0x02 0x00 0x01 0x00 0x02 0x10 0x01 0x00 0x00 0x01 0x05 0x02 0x00 0x02 0x02 0x02 0x05 0x02 0x00 0x00 0x02 0x01 0x03 0x01 0x00 0x01 0x02 0x03 0x02 0x00 0x00 0x01 0x02 0x03 0x02 0x00 0x00 0x03 0x01 0x03 0x01 0x00 0x01 0x02 0x03 0x02 0x00 0x00 0x01
[   19.108167] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.121870] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.121884] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.121891] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.121920] [STP-BTM] [W]_stp_btm_handler: get consys dump num packet_num(7)
[   19.125197] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   19.133763] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.147530] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.147566] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.161158] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.161184] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.161190] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.172907] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.186612] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.186645] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.200266] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.200284] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.200290] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.212049] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.225818] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.225861] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.231927] 0x3c 0x41 0x53 0x53 0x45 0x52 0x54 0x3e 0x20 0x77 0x69 0x66 0x69 0x2f 0x6e 0x69
[   19.231928] g_coredump_mode: 0!
[   19.246953] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.246969] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.246975] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.258819] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.272640] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.272651] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.272657] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.284618] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.298867] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.298900] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.313100] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.313123] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.313129] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.325393] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.339709] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.339753] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.353735] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.353751] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.353757] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.366032] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.380127] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.380156] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.394198] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.394210] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.394222] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.406415] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.420625] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.420660] drivers/misc/mediatek/connectivity/common/conn_soc/core/btm_core.c, 824, (!RB_EMPTY(pOpQ))
[   19.435243] [STP-BTM] [W]_stp_btm_get_op: RB_GET fail
[   19.435257] [STP-BTM] [W]_stp_btm_dump_type: get_free_lxop fail
[   19.435267] [STP-BTM] [E]_stp_btm_notify_wmt_dmp_wq(1132):ERROR! paged dump fail
[   19.441717] [STP-BTM] [E]_stp_btm_handler(750):ERROR! polling CTRL STATE fail
[   19.441763] [STP-BTM] [W]_stp_btm_proc: opid id(0x7)(STP_OPID_BTM_PAGED_TRACE) error(-1)
[   19.441842] [MTK-WIFI] wifi_reset_start: Turn off p2p/ap mode
[   19.441843] [STP-PSM] [W]_stp_psm_put_op: RB_FULL, RB_COUNT=16 , RB_SIZE=16
[   19.441845] [STP-PSM] [W]_stp_psm_proc: +++++++++++ Put op to FreeOpQ fail, maybe disable/enable psm
[   19.441870] [WMT-CTRL][W]wmt_ctrl_rx:wmt_ctrl_rx be signaled, but no rx data(1966)
[   21.441614] [WMT-LIB][E]wmt_lib_put_act_op(1056):wait completion timeout, opId(19), show wmtd_thread stack!
[   21.456326] [<c0ad23f0>] (__schedule) from [<c0ad28c0>] (schedule+0x50/0xa8)
[   21.456342] [<c0ad28c0>] (schedule) from [<c0ad574c>] (schedule_timeout+0x144/0x244)
[   21.456355] [<c0ad574c>] (schedule_timeout) from [<c0700454>] (wmt_dev_rx_timeout+0x154/0x1b0)
[   21.456369] [<c0700454>] (wmt_dev_rx_timeout) from [<c06e4e9c>] (wmt_ctrl_rx+0x180/0x294)
[   21.456381] [<c06e4e9c>] (wmt_ctrl_rx) from [<c06e5824>] (wmt_ctrl+0x44/0xc0)
[   21.456391] [<c06e5824>] (wmt_ctrl) from [<c06e0c20>] (wmt_core_rx+0x34/0x88)
[   21.456401] [<c06e0c20>] (wmt_core_rx) from [<c06e2334>] (opfunc_pwr_sv+0x228/0x6dc)
[   21.456412] [<c06e2334>] (opfunc_pwr_sv) from [<c06e1ca0>] (wmt_core_opid_handler+0x34/0x54)
[   21.456421] [<c06e1ca0>] (wmt_core_opid_handler) from [<c06e1cec>] (wmt_core_opid+0x2c/0x6c)
[   21.456432] [<c06e1cec>] (wmt_core_opid) from [<c06eb044>] (wmtd_thread+0x1a0/0x254)
[   21.456447] [<c06eb044>] (wmtd_thread) from [<c0053dac>] (kthread+0x108/0x120)
[   21.456463] [<c0053dac>] (kthread) from [<c000fd38>] (ret_from_fork+0x14/0x3c)
[   21.456474] [WMT-LIB][W]wmt_lib_hw_state_show:WMT_OPID_HW_STATE_SHOW failed
[   23.451669] [WMT-LIB][E]wmt_lib_put_act_op(1056):wait completion timeout, opId(11), show wmtd_thread stack!
[   23.466709] [<c0ad23f0>] (__schedule) from [<c0ad28c0>] (schedule+0x50/0xa8)
[   23.466731] [<c0ad28c0>] (schedule) from [<c0ad574c>] (schedule_timeout+0x144/0x244)
[   23.466748] [<c0ad574c>] (schedule_timeout) from [<c0700454>] (wmt_dev_rx_timeout+0x154/0x1b0)
[   23.466766] [<c0700454>] (wmt_dev_rx_timeout) from [<c06e4e9c>] (wmt_ctrl_rx+0x180/0x294)
[   23.466781] [<c06e4e9c>] (wmt_ctrl_rx) from [<c06e5824>] (wmt_ctrl+0x44/0xc0)
[   23.466792] [<c06e5824>] (wmt_ctrl) from [<c06e0c20>] (wmt_core_rx+0x34/0x88)
[   23.466808] [<c06e0c20>] (wmt_core_rx) from [<c06e2334>] (opfunc_pwr_sv+0x228/0x6dc)
[   23.466831] [<c06e2334>] (opfunc_pwr_sv) from [<c06e1ca0>] (wmt_core_opid_handler+0x34/0x54)
[   23.466848] [<c06e1ca0>] (wmt_core_opid_handler) from [<c06e1cec>] (wmt_core_opid+0x2c/0x6c)
[   23.466869] [<c06e1cec>] (wmt_core_opid) from [<c06eb044>] (wmtd_thread+0x1a0/0x254)
[   23.466887] [<c06eb044>] (wmtd_thread) from [<c0053dac>] (kthread+0x108/0x120)
[   23.466904] [<c0053dac>] (kthread) from [<c000fd38>] (ret_from_fork+0x14/0x3c)
[   23.466915] [WMT-LIB][W]wmt_lib_hw_rst:WMT_OPID_HW_RST failed
[   23.466923] [WMT-LIB][E]wmt_lib_cmb_rst(1674):[whole chip reset] fail at wmt_lib_hw_rst!
[   25.471611] [WMT-LIB][E]wmt_lib_put_act_op(1056):wait completion timeout, opId(19), show wmtd_thread stack!
[   25.486285] [<c0ad23f0>] (__schedule) from [<c0ad28c0>] (schedule+0x50/0xa8)
[   25.486300] [<c0ad28c0>] (schedule) from [<c0ad574c>] (schedule_timeout+0x144/0x244)
[   25.486313] [<c0ad574c>] (schedule_timeout) from [<c0700454>] (wmt_dev_rx_timeout+0x154/0x1b0)
[   25.486328] [<c0700454>] (wmt_dev_rx_timeout) from [<c06e4e9c>] (wmt_ctrl_rx+0x180/0x294)
[   25.486339] [<c06e4e9c>] (wmt_ctrl_rx) from [<c06e5824>] (wmt_ctrl+0x44/0xc0)
[   25.486350] [<c06e5824>] (wmt_ctrl) from [<c06e0c20>] (wmt_core_rx+0x34/0x88)
[   25.486360] [<c06e0c20>] (wmt_core_rx) from [<c06e2334>] (opfunc_pwr_sv+0x228/0x6dc)
[   25.486370] [<c06e2334>] (opfunc_pwr_sv) from [<c06e1ca0>] (wmt_core_opid_handler+0x34/0x54)
[   25.486379] [<c06e1ca0>] (wmt_core_opid_handler) from [<c06e1cec>] (wmt_core_opid+0x2c/0x6c)
[   25.486390] [<c06e1cec>] (wmt_core_opid) from [<c06eb044>] (wmtd_thread+0x1a0/0x254)
[   25.486405] [<c06eb044>] (wmtd_thread) from [<c0053dac>] (kthread+0x108/0x120)
[   25.486419] [<c0053dac>] (kthread) from [<c000fd38>] (ret_from_fork+0x14/0x3c)
[   25.486430] [WMT-LIB][W]wmt_lib_hw_state_show:WMT_OPID_HW_STATE_SHOW failed
[   27.481631] [WMT-LIB][E]wmt_lib_put_act_op(1056):wait completion timeout, opId(11), show wmtd_thread stack!
[   27.496216] [<c0ad23f0>] (__schedule) from [<c0ad28c0>] (schedule+0x50/0xa8)
[   27.496230] [<c0ad28c0>] (schedule) from [<c0ad574c>] (schedule_timeout+0x144/0x244)
[   27.496244] [<c0ad574c>] (schedule_timeout) from [<c0700454>] (wmt_dev_rx_timeout+0x154/0x1b0)
[   27.496258] [<c0700454>] (wmt_dev_rx_timeout) from [<c06e4e9c>] (wmt_ctrl_rx+0x180/0x294)
[   27.496270] [<c06e4e9c>] (wmt_ctrl_rx) from [<c06e5824>] (wmt_ctrl+0x44/0xc0)
[   27.496281] [<c06e5824>] (wmt_ctrl) from [<c06e0c20>] (wmt_core_rx+0x34/0x88)
[   27.496291] [<c06e0c20>] (wmt_core_rx) from [<c06e2334>] (opfunc_pwr_sv+0x228/0x6dc)
[   27.496301] [<c06e2334>] (opfunc_pwr_sv) from [<c06e1ca0>] (wmt_core_opid_handler+0x34/0x54)
[   27.496311] [<c06e1ca0>] (wmt_core_opid_handler) from [<c06e1cec>] (wmt_core_opid+0x2c/0x6c)
[   27.496322] [<c06e1cec>] (wmt_core_opid) from [<c06eb044>] (wmtd_thread+0x1a0/0x254)
[   27.496337] [<c06eb044>] (wmtd_thread) from [<c0053dac>] (kthread+0x108/0x120)
[   27.496351] [<c0053dac>] (kthread) from [<c000fd38>] (ret_from_fork+0x14/0x3c)
[   27.496362] [WMT-LIB][W]wmt_lib_hw_rst:WMT_OPID_HW_RST failed
[   27.496370] [WMT-LIB][E]wmt_lib_cmb_rst(1674):[whole chip reset] fail at wmt_lib_hw_rst!
[   29.501653] [WMT-LIB][E]wmt_lib_put_act_op(1056):wait completion timeout, opId(19), show wmtd_thread stack!
[   29.516511] [<c0ad23f0>] (__schedule) from [<c0ad28c0>] (schedule+0x50/0xa8)
[   29.516527] [<c0ad28c0>] (schedule) from [<c0ad574c>] (schedule_timeout+0x144/0x244)
[   29.516537] [<c0ad574c>] (schedule_timeout) from [<c0700454>] (wmt_dev_rx_timeout+0x154/0x1b0)
[   29.516548] [<c0700454>] (wmt_dev_rx_timeout) from [<c06e4e9c>] (wmt_ctrl_rx+0x180/0x294)
[   29.516561] [<c06e4e9c>] (wmt_ctrl_rx) from [<c06e5824>] (wmt_ctrl+0x44/0xc0)
[   29.516572] [<c06e5824>] (wmt_ctrl) from [<c06e0c20>] (wmt_core_rx+0x34/0x88)
[   29.516582] [<c06e0c20>] (wmt_core_rx) from [<c06e2334>] (opfunc_pwr_sv+0x228/0x6dc)
[   29.516592] [<c06e2334>] (opfunc_pwr_sv) from [<c06e1ca0>] (wmt_core_opid_handler+0x34/0x54)
[   29.516602] [<c06e1ca0>] (wmt_core_opid_handler) from [<c06e1cec>] (wmt_core_opid+0x2c/0x6c)
[   29.516614] [<c06e1cec>] (wmt_core_opid) from [<c06eb044>] (wmtd_thread+0x1a0/0x254)
[   29.516628] [<c06eb044>] (wmtd_thread) from [<c0053dac>] (kthread+0x108/0x120)
[   29.516644] [<c0053dac>] (kthread) from [<c000fd38>] (ret_from_fork+0x14/0x3c)
[   29.516656] [WMT-LIB][W]wmt_lib_hw_state_show:WMT_OPID_HW_STATE_SHOW failed
[   30.091602] br0: port 1(eth1) entered forwarding state
[   30.091671] br0: port 2(eth0) entered forwarding state
[   31.511696] [WMT-LIB][E]wmt_lib_put_act_op(1056):wait completion timeout, opId(11), show wmtd_thread stack!
[   31.526371] [<c0ad23f0>] (__schedule) from [<c0ad28c0>] (schedule+0x50/0xa8)
[   31.526391] [<c0ad28c0>] (schedule) from [<c0ad574c>] (schedule_timeout+0x144/0x244)
[   31.526406] [<c0ad574c>] (schedule_timeout) from [<c0700454>] (wmt_dev_rx_timeout+0x154/0x1b0)
[   31.526422] [<c0700454>] (wmt_dev_rx_timeout) from [<c06e4e9c>] (wmt_ctrl_rx+0x180/0x294)
[   31.526434] [<c06e4e9c>] (wmt_ctrl_rx) from [<c06e5824>] (wmt_ctrl+0x44/0xc0)
[   31.526445] [<c06e5824>] (wmt_ctrl) from [<c06e0c20>] (wmt_core_rx+0x34/0x88)
[   31.526455] [<c06e0c20>] (wmt_core_rx) from [<c06e2334>] (opfunc_pwr_sv+0x228/0x6dc)
[   31.526466] [<c06e2334>] (opfunc_pwr_sv) from [<c06e1ca0>] (wmt_core_opid_handler+0x34/0x54)
[   31.526476] [<c06e1ca0>] (wmt_core_opid_handler) from [<c06e1cec>] (wmt_core_opid+0x2c/0x6c)
[   31.526487] [<c06e1cec>] (wmt_core_opid) from [<c06eb044>] (wmtd_thread+0x1a0/0x254)
[   31.526502] [<c06eb044>] (wmtd_thread) from [<c0053dac>] (kthread+0x108/0x120)
[   31.526518] [<c0053dac>] (kthread) from [<c000fd38>] (ret_from_fork+0x14/0x3c)
[   31.526529] [WMT-LIB][W]wmt_lib_hw_rst:WMT_OPID_HW_RST failed
[   31.526538] [WMT-LIB][E]wmt_lib_cmb_rst(1674):[whole chip reset] fail at wmt_lib_hw_rst!
[   33.531667] [WMT-LIB][E]wmt_lib_put_act_op(1056):wait completion timeout, opId(19), show wmtd_thread stack!
[   33.546432] [<c0ad23f0>] (__schedule) from [<c0ad28c0>] (schedule+0x50/0xa8)
[   33.546453] [<c0ad28c0>] (schedule) from [<c0ad574c>] (schedule_timeout+0x144/0x244)
[   33.546467] [<c0ad574c>] (schedule_timeout) from [<c0700454>] (wmt_dev_rx_timeout+0x154/0x1b0)
[   33.546481] [<c0700454>] (wmt_dev_rx_timeout) from [<c06e4e9c>] (wmt_ctrl_rx+0x180/0x294)
[   33.546493] [<c06e4e9c>] (wmt_ctrl_rx) from [<c06e5824>] (wmt_ctrl+0x44/0xc0)
[   33.546504] [<c06e5824>] (wmt_ctrl) from [<c06e0c20>] (wmt_core_rx+0x34/0x88)
[   33.546514] [<c06e0c20>] (wmt_core_rx) from [<c06e2334>] (opfunc_pwr_sv+0x228/0x6dc)
[   33.546524] [<c06e2334>] (opfunc_pwr_sv) from [<c06e1ca0>] (wmt_core_opid_handler+0x34/0x54)
[   33.546534] [<c06e1ca0>] (wmt_core_opid_handler) from [<c06e1cec>] (wmt_core_opid+0x2c/0x6c)
[   33.546545] [<c06e1cec>] (wmt_core_opid) from [<c06eb044>] (wmtd_thread+0x1a0/0x254)
[   33.546560] [<c06eb044>] (wmtd_thread) from [<c0053dac>] (kthread+0x108/0x120)
[   33.546576] [<c0053dac>] (kthread) from [<c000fd38>] (ret_from_fork+0x14/0x3c)
[   33.546589] [WMT-LIB][W]wmt_lib_hw_state_show:WMT_OPID_HW_STATE_SHOW failed
[   35.493761] [WDK]: kick Ex WDT
[   35.494368] [WDK]: kick Ex WDT
[   35.494519] [WDK]: kick Ex WDT
[   35.496202] [WDK]: kick Ex WDT
[   35.496352] [WDK]: kick Ex WDT
[   35.496536] [WDK]: kick Ex WDT
[   35.496686] [WDK]: kick Ex WDT
[   35.496900] [WDK]: kick Ex WDT
[   35.497053] [WDK]: kick Ex WDT
[   35.497206] [WDK]: kick Ex WDT
[   35.497390] [WDK]: kick Ex WDT
[   35.497540] [WDK]: kick Ex WDT
[   35.541696] [WMT-LIB][E]wmt_lib_put_act_op(1056):wait completion timeout, opId(11), show wmtd_thread stack!
[   35.551670] [<c0ad23f0>] (__schedule) from [<c0ad28c0>] (schedule+0x50/0xa8)
[   35.551689] [<c0ad28c0>] (schedule) from [<c0ad574c>] (schedule_timeout+0x144/0x244)
[   35.551702] [<c0ad574c>] (schedule_timeout) from [<c0700454>] (wmt_dev_rx_timeout+0x154/0x1b0)
[   35.551716] [<c0700454>] (wmt_dev_rx_timeout) from [<c06e4e9c>] (wmt_ctrl_rx+0x180/0x294)
[   35.551728] [<c06e4e9c>] (wmt_ctrl_rx) from [<c06e5824>] (wmt_ctrl+0x44/0xc0)
[   35.551738] [<c06e5824>] (wmt_ctrl) from [<c06e0c20>] (wmt_core_rx+0x34/0x88)
[   35.551748] [<c06e0c20>] (wmt_core_rx) from [<c06e2334>] (opfunc_pwr_sv+0x228/0x6dc)
[   35.551758] [<c06e2334>] (opfunc_pwr_sv) from [<c06e1ca0>] (wmt_core_opid_handler+0x34/0x54)
[   35.551767] [<c06e1ca0>] (wmt_core_opid_handler) from [<c06e1cec>] (wmt_core_opid+0x2c/0x6c)
[   35.551779] [<c06e1cec>] (wmt_core_opid) from [<c06eb044>] (wmtd_thread+0x1a0/0x254)
[   35.551793] [<c06eb044>] (wmtd_thread) from [<c0053dac>] (kthread+0x108/0x120)
[   35.551808] [<c0053dac>] (kthread) from [<c000fd38>] (ret_from_fork+0x14/0x3c)
[   35.551819] [WMT-LIB][W]wmt_lib_hw_rst:WMT_OPID_HW_RST failed
[   35.551827] [WMT-LIB][E]wmt_lib_cmb_rst(1674):[whole chip reset] fail at wmt_lib_hw_rst!
I get the above logs many times (almost one each minute?), sometimes it’s followed by the following log:
[  591.267678] [WMT-LIB][W]wmt_lib_hw_state_show:WMT_OPID_HW_STATE_SHOW failed
[  592.591955] [WMT-DEV][E]wmt_dev_rx_timeout(1430):gRxCount != 0 (-1), reset it!
[  592.664334] [WMT-CTRL][E]wmt_ctrl_rx(263):wmt_dev_rx_timeout: timeout,jiffies(29265),timeoutvalue(20000)
[  592.678873] [WMT-CORE][E]wmt_core_rx(346):WMT-CORE: wmt_core_ctrl failed: WMT_CTRL_RX, iRet:-1
[  592.692499] drivers/misc/mediatek/connectivity/common/conn_soc/core/wmt_core.c, 348, (0)
[  592.705570] [WMT-CORE][E]opfunc_pwr_sv(1269):wmt_core: read WAKEUP_EVT fail(-1) len(0, 6)
[  592.713707] [WMT-CTRL][E]wmt_ctrl_evt_parser(969):parser wmt evt from BTIF buf fail(0)
[  592.731869] [WMT-CORE][E]wmt_core_ctrl(500):WMT-CORE: wmt_core_ctrl failed: id(29), type(2), value(0) iRet:(-1)
[  592.747062] drivers/misc/mediatek/connectivity/common/conn_soc/core/wmt_core.c, 501, (0)
[  592.760289] [WMT-CTRL][W]wmt_ctrl_evt_err_trg_assert:wmt-ctrl:drv_type(4),reason(34)
[  592.760310] [STP-PSM] [E]_stp_psm_notify_stp(1007):ERROR! Action = WAKEUP, ACT state, the case should not happens
[  592.775826] [STP-PSM] [E]_stp_psm_notify_stp(1008):ERROR! state = 0, flag = 40
[  592.793488] [WMT-LIB][W]wmtd_thread:opid (7) failed, iRet(-1)
[  592.793510] [WMT-CORE][W]wmt_core_dump_func_state:[BE HW RST]status(b:0 f:0 g:0 w:2 lpbk:0 coredump:0 wmt:2 stp:0)
[  592.793522] [WMT-FUNC][W]wmt_func_wifi_off:WMT-FUNC: wmt wlan func on before wlan remove
[  592.793530] [MTK-WIFI] register_set_p2p_mode_handler: (pid 489) register set p2p mode handler   (null)
[  592.981555] [WMT-FUNC][W]wmt_func_wifi_off:WMT-FUNC: wmt call wlan remove ok
[  593.042226] vcn18: mode operation not allowed
[  593.115297] vcn18: mode operation not allowed
[  593.129054] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(292):Read CONSYS chipId(0xfffff093)
[  593.211423] [WMT-CORE][W]opfunc_hw_rst:WMT-CORE: -->[HW RST] ok
[  593.216702] [WMT-CORE][W]wmt_core_dump_func_state:[AF HW RST]status(b:0 f:0 g:0 w:0 lpbk:0 coredump:0 wmt:1 stp:0)
[  593.216868] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[  593.291907] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6620.defAnt, mt6620_ant_m3.cfg, -1)
[  593.292114] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[  593.304472] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6628.defAnt, mt6628_ant_m1.cfg, -1)
[  593.304487] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[  593.316597] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6630.defAnt, mt6630_ant_m1.cfg, -1)
[  593.318476] [WMT-IC][W]mtk_wcn_soc_ver_check:0x7623: read hw_ver (hw version) (0x8a00)
[  593.319373] [WMT-IC][W]mtk_wcn_soc_ver_check:0x7623: read fw_ver (rom version) (0x8a00)
[  593.319386] [WMT-IC][W]mtk_wcn_soc_ver_check:0x7623: ic info: SOC_CONSYS.E1 (0x8a00/0x8a00, WMTHWVER:0, patch_ext:_e1)
[  593.395408] [WMT-IC][W]mtk_wcn_soc_patch_dwn:wmt_core: patch dwn:0 frag(51, 268) ok
[  593.568587] [WMT-IC][W]mtk_wcn_soc_patch_dwn:wmt_core: patch dwn:0 frag(114, 52) ok
[  593.893784] [WMT-IC][W]mtk_wcn_soc_sw_init:co-clock disabled.
[  593.895192] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
[  593.895658] [STP-BTM] [W]_stp_btm_put_op: RB_FULL(0xc11333b8) 64 ,rFreeOpQ = c11333b8, rActiveOpQ = c11334dc
[  593.895962] [MTK-WIFI] wifi_reset_end: WIFI state recovering...
[  593.896373] [WMT-FUNC][W]wmt_func_wifi_on:WMT-FUNC: wmt wlan func on before wlan probe
[  594.934076] [MTK-WIFI] register_set_p2p_mode_handler: (pid 489) register set p2p mode handler c07217a4
[  594.934107] [WMT-FUNC][W]wmt_func_wifi_on:WMT-FUNC: wmt call wlan probe ok
[  594.934120] [WMT-CORE][W]wmt_core_dump_func_state:[AF FUNC ON]status(b:0 f:0 g:0 w:2 lpbk:0 coredump:0 wmt:2 stp:0)
[  594.934195] [WMT-EXP][W]mtk_wcn_wmt_func_ctrl:OPID(3) type(3) ok
[  594.934205] [MTK-WIFI] wifi_reset_end: WMT turn on WIFI success!
[  594.935364] [MTK-WIFI] wifi_reset_end: Set wlan mode 1
(gary) #47
Hi Enfide
Please remove the wpa_supplicant package when it’s in AP mode, because it will cause this issue.
#48
Thank you Gary! Sorry for the question, I forgot about it…
To disable the service from systemd I executed:
systemctl mask wpa_supplicant.service
So I can still use wpa_supplicant on other interfaces. nmcli doesn’t work anymore for wifi devices but this is not an issue as we use hostapd to provide AP.
(Benoit) #49
Or a clear instructions for use wifi apmode a switch/vlan?
(Frank W.) #50
switch/vlan will not be available in 4.4.70, ap seems to work stable in my (short) tests
why a new image when you simply can replace kernel?
(Benoit) #51
Just out of simplicity, I don’t have any other machine under ubuntu for compile kernel. What is the procedure for activating the ap-mode? I have tried: Echo A>/dev/wmtWifi and killall wpa_supplicant apt-get remove wpa_supplicant echo 1>$… is uncommented and reboot but ap-mode is not available (I have an errror message: ap-mode is disabled)
(Frank W.) #52
only echo 0 and echo A…before that the 2 other commands…no reboot
(Benoit) #53
hello, I have done echo 0, echo A After: killall wpa_supplicant=>wpa_supplicant: no process found When I launch: hostapd -dd /etc/hostapd/hostapd.conf (this hostapd.conf is good It’s tried on a Pi2) I have:
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 8 iftype 3 (AP)
nl80211: Failed to set interface 8 to mode 3: -95 (Operation not supported)
nl80211: Try mode change after setting interface down
nl80211: Interface mode change to 3 from 0 failed
nl80211: Could not configure driver mode
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=8 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)nl80211: Set mode ifindex 8 iftype 2 (STATION)
nl80211 driver initialization failed.
hostapd_interface_deinit_free(0x7f6fbcd8)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0x7f6fbcd8)
wlan0: interface state UNINITIALIZED->DISABLED
hostapd_bss_deinit: deinit bss wlan0
wlan0: AP-DISABLED
hostapd_cleanup(hapd=0x7f6fc9a0 (wlan0))
hostapd_free_hapd_data: Interface wlan0 wasn't started
hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit
hostapd_interface_free(0x7f6fbcd8)
hostapd_interface_free: free hapd 0x7f6fc9a0
hostapd_cleanup_iface(0x7f6fbcd8)
hostapd_cleanup_iface_partial(0x7f6fbcd8)
hostapd_cleanup_iface: free iface=0x7f6fbcd8
(Frank W.) #54
like described here http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:wlan#internal
wmt_loader
stp_uart_launcher -p /etc/firmware &
echo 0 >/dev/wmtWifi (reset/initialize)
echo A >/dev/wmtWifi (activate AP-Mode)
have you done steps 1 & 2?
also you must start hostapd on ap0 instead of wlan0
#55
2 additional points:
  • After a clean boot, you dont have to use “echo 0”. It works when you do the first 2 steps that Frank suggests and then “echo A
  • Make sure you have the firmware files in /etc/firmware.
Indeed most likely you just need to use ap0 instead of wlan0.
Read this manual for original instructions.
(Benoit) #56
ok it’s works fine, But it’s too bad we can only use with a single SSID!! I need to install a usb dongle for use a second SSID!
(Frank W.) #57
1 adapter = 1 AP
You can also use pcie for a second card
(Benoit) #58
I know some adapter witch support 5 Ap by Adapter
(hyh) #59
Hello Everyone. I have a bad English.
I have a bpi-r2 and I wang to use AP-mode. Recently , I very surprised that a new image is released.
I using 2017-11-28-ubuntu-16.04-mate-desktop-bpi-r2-sd-emmc.img.zip. on eMMC.
I do this step by step.
However ,I can’t find the ap0 interface.
I try to “wmt_loader” , but
I try to “stp_uart_launcher -p /etc/firmware &” , but
Can’t open device node(/dev/stpwmt) error:-1
Anyone can help me ? Thank a lot.
(Frank W.) #60
You must do it in right order
