2.4Ghz and 5.6Ghz Wifi Working fine
(Aaron Gray) #1
Both low and high band Wifi are working correctly on both releases :-
2017-08-01-ubuntu-16.04-mate-desktop-docker-preview2-bpi-r2-sd-emmc.img
2017-09-04-ubuntu-16.04-mate-desktop-bpi-r2-sd-emmc-v1.2.0.img
user do some test for 2.4G & 5.8G,for reference only
5.8G test:
2.4G test:
PI BPI R2 How I create HotSpot
Unable to use AP mode
(Benoit) #2
Do you have tried on AP Mode?
(gary) #3
The AP mode isn’t working yet, I will debug it when I finish higher priority tasks,
(Frank W.) #4
Can you explain how you created the image? then we can do same steps e.g. for debian (jessie/stretch)
I’ve compiled kernel from github…but how to work further without using an existing image and replacing there.
(gary) #5
Hi frank
We don’t have an instruction to describe how to create a debian image withtout using an available image yet
(Frank W.) #6
ok, thanks for now, jessie is running, i try kernel upgrade :wink: waiting for AP-Mode :slight_smile:
(chris) #7
We are very interested in AP mode for the MT7615 ad- in cards. Gemtek/AsiaRF etc. When will AP mode support get resources? Also would love to get support for the Qualcomm wifi cards like the Compex 4x4 cards
(Benoit) #8
hello, do you have a news?
(gary) #9
Hi Ben
The AP mode is not working fine, so far we don’t have a plan to fix this,
Thanks Gary
(chris) #10
What is the value of this board without AP mode? Why is the BananaPi team not providing further support for AP mode it is detrimental to the platform.
(Maciek Szelągowski) #11
Do I understand right? We will have no possibility to use R2 as wireless access point? If yes this board is useless …
(Aaron Gray) #12
Not sure but the HostAP mailing list might be of some help :-
https://lists.infradead.org/mailman/listinfo/hostap
(Frank W.) #13
the problem is there is no full driver support, it’s not fault of hostapd…hostapd only USES that driver
(gary) #14
Hi All
I’m debug AP mode, After reviewing the code, I find a way to enable it, but it doesn’t work for me:
Steps to enable AP mode(not vaildated yet):
  1. echo A > /dev/wmtWifi
  2. killall wpa_supplicant
  3. hostapd -B -dd /etc/hostapd/hostapd.conf
(Dino Chang) #15
Hi Gary,
After you echo A to /dev/wmtWifi, it should have a device node called /dev/apX. In your hostapd.conf, you must change the interface name to apX, not wlanX.
(gary) #16
Thanks a lot.
On my board, the interface is configured to ap0. Does the AP mode work on your board?
(Frank W.) #17
What does “does not work” mean? Any error-messages, which Problems?
(gary) #18
Don’t see any error log on console, but can’t find out the SSID.
#19
Gary, I tried with following nmcli commands and I see tons of errors in syslog (I also got a kernel crash):
create the connection
  • nmcli connection add type wifi ifname ap0 con-name wlanAP autoconnect no ssid BananaR2
  • nmcli connection modify wlanAP 802-11-wireless.mode ap 802-11-wireless.band bg ipv4.method shared
  • nmcli connection modify wlanAP wifi-sec.key-mgmt wpa-psk
  • nmcli connection modify wlanAP wifi-sec.psk “12345678”
enable the connection
  • nmcli connection up wlanAP
#20
For me it works briefly. The SSID is visible at first, but when I try to connect there is a kernel panic (see below). From that point, the system is broken.
I’m running on ArchlinuxARM with a kernel from BPI-R2 github page and default configuration. hostapd with default config as well.
[ 1015.666910] [MTK-WIFI] WIFI_open: WIFI_open: major 153 minor 0 (pid 8160)
[ 1015.684243] [MTK-WIFI] WIFI_write: WIFI_write A
[ 1015.731654] [WMT-FUNC][W]wmt_func_wifi_on:WMT-FUNC: wmt wlan func on before wlan probe
[ 1016.804540] [MTK-WIFI] register_set_p2p_mode_handler: (pid 8184) register set p2p mode handler c071f534
[ 1016.824227] [WMT-FUNC][W]wmt_func_wifi_on:WMT-FUNC: wmt call wlan probe ok
[ 1016.841654] [WMT-CORE][W]wmt_core_dump_func_state:[AF FUNC ON]status(b:0 f:0 g:0 w:2 lpbk:2 coredump:0 wmt:2 stp:0)
[ 1016.864324] [WMT-EXP][W]mtk_wcn_wmt_func_ctrl:OPID(3) type(3) ok
[ 1016.881505] [MTK-WIFI] WIFI_write: WMT turn on WIFI success!
[ 1016.898993] [MTK-WIFI] WIFI_write: Set wlan mode 0 --> 1
[ 1016.914772] [MTK-WIFI] WIFI_close: WIFI_close: major 153 minor 0 (pid 8160)
[ 1281.064828] ------------[ cut here ]------------
[ 1281.079627] WARNING: CPU: 1 PID: 8197 at net/wireless/nl80211.c:3618 nl80211_put_sta_rate+0xf8/0x1f8()
[ 1281.099112] Modules linked in: input_leds led_class ahci libahci libata mtk_thermal mtk_cir ip_tables x_tables
[ 1281.119464] CPU: 1 PID: 8197 Comm: tx_thread Not tainted 4.4.70-BPI-R2-Kernel #2
[ 1281.136976] Hardware name: Mediatek Cortex-A7 (Device Tree)
[ 1281.152708] [<c001a180>] (unwind_backtrace) from [<c0014c1c>] (show_stack+0x20/0x24)
[ 1281.170691] [<c0014c1c>] (show_stack) from [<c0564048>] (dump_stack+0x94/0xa8)
[ 1281.188082] [<c0564048>] (dump_stack) from [<c0034944>] (warn_slowpath_common+0x94/0xc4)
[ 1281.206255] [<c0034944>] (warn_slowpath_common) from [<c0034a30>] (warn_slowpath_null+0x2c/0x34)
[ 1281.225180] [<c0034a30>] (warn_slowpath_null) from [<c0aa2adc>] (nl80211_put_sta_rate+0xf8/0x1f8)
[ 1281.244195] [<c0aa2adc>] (nl80211_put_sta_rate) from [<c0a7a08c>] (nl80211_send_station+0x4f8/0xb1c)
[ 1281.263549] [<c0a7a08c>] (nl80211_send_station) from [<c0a7a740>] (cfg80211_new_sta+0x90/0x18c)
[ 1281.282483] [<c0a7a740>] (cfg80211_new_sta) from [<c0735124>] (kalP2PGOStationUpdate+0x94/0x9c)
[ 1281.301426] [<c0735124>] (kalP2PGOStationUpdate) from [<c074fc5c>] (p2pRunEventAAASuccess+0x24/0x2c)
[ 1281.320844] [<c074fc5c>] (p2pRunEventAAASuccess) from [<c0739f44>] (aaaFsmRunEventTxDone+0x194/0x19c)
[ 1281.340460] [<c0739f44>] (aaaFsmRunEventTxDone) from [<c07187e8>] (nicRxProcessEventPacket+0x7f4/0x9b4)
[ 1281.360288] [<c07187e8>] (nicRxProcessEventPacket) from [<c0718b10>] (nicRxProcessRFBs+0xbc/0x188)
[ 1281.379755] [<c0718b10>] (nicRxProcessRFBs) from [<c0718ea8>] (nicProcessRxInterrupt+0x3c/0x40)
[ 1281.399042] [<c0718ea8>] (nicProcessRxInterrupt) from [<c07122bc>] (nicProcessIST_impl+0x5c/0xb4)
[ 1281.418511] [<c07122bc>] (nicProcessIST_impl) from [<c071236c>] (nicProcessIST+0x58/0xa4)
[ 1281.437278] [<c071236c>] (nicProcessIST) from [<c07045a8>] (wlanIST+0x50/0x9c)
[ 1281.455021] [<c07045a8>] (wlanIST) from [<c0722c2c>] (tx_thread+0x3bc/0x440)
[ 1281.472548] [<c0722c2c>] (tx_thread) from [<c0054350>] (kthread+0x118/0x120)
[ 1281.490061] [<c0054350>] (kthread) from [<c0010038>] (ret_from_fork+0x14/0x3c)
[ 1281.507806] ---[ end trace 2a0a5799a7240bb4 ]---
Edit: I’ve added a printk just before the switch case near line 3618 in net/wireless/nl80211.c, printing info->bw. In a single run, the printk got hit twice:
[  108.431013] nl80211_put_sta_rate(3610): info->bw=218
PANIC TRACE
[  109.266831] nl80211_put_sta_rate(3610): info->bw=223
PANIC TRACE
Both values do not match a value from enum rate_info_bw, hitting the default clause, triggering the trace output. I will try to find where this value is determined.
Then, subsequently, a different trace is printed:
[  108.780753] ------------[ cut here ]------------
[  108.795727] WARNING: CPU: 3 PID: 418 at net/wireless/util.c:1124 cfg80211_calculate_bitrate+0x208/0x238()
[  108.815771] Modules linked in: ahci libahci libata mtk_cir mtk_thermal ip_tables x_tables
[  108.834560] CPU: 3 PID: 418 Comm: tx_thread Tainted: G        W       4.4.70-BPI-R2-Kernel #3
[  108.853563] Hardware name: Mediatek Cortex-A7 (Device Tree)
[  108.869589] [<c001a180>] (unwind_backtrace) from [<c0014c1c>] (show_stack+0x20/0x24)
[  108.887806] [<c0014c1c>] (show_stack) from [<c0564048>] (dump_stack+0x94/0xa8)
[  108.905474] [<c0564048>] (dump_stack) from [<c0034944>] (warn_slowpath_common+0x94/0xc4)
[  108.923982] [<c0034944>] (warn_slowpath_common) from [<c0034a30>] (warn_slowpath_null+0x2c/0x34)
[  108.943183] [<c0034a30>] (warn_slowpath_null) from [<c0a5ef08>] (cfg80211_calculate_bitrate+0x208/0x238)
[  108.963169] [<c0a5ef08>] (cfg80211_calculate_bitrate) from [<c0aa2a3c>] (nl80211_put_sta_rate+0x58/0x214)
[  108.983277] [<c0aa2a3c>] (nl80211_put_sta_rate) from [<c0a7a08c>] (nl80211_send_station+0x4f8/0xb1c)
[  109.002970] [<c0a7a08c>] (nl80211_send_station) from [<c0a7a740>] (cfg80211_new_sta+0x90/0x18c)
[  109.022195] [<c0a7a740>] (cfg80211_new_sta) from [<c0735124>] (kalP2PGOStationUpdate+0x94/0x9c)
[  109.041497] [<c0735124>] (kalP2PGOStationUpdate) from [<c074fc5c>] (p2pRunEventAAASuccess+0x24/0x2c)
[  109.061335] [<c074fc5c>] (p2pRunEventAAASuccess) from [<c0739f44>] (aaaFsmRunEventTxDone+0x194/0x19c)
[  109.081261] [<c0739f44>] (aaaFsmRunEventTxDone) from [<c07187e8>] (nicRxProcessEventPacket+0x7f4/0x9b4)
[  109.101407] [<c07187e8>] (nicRxProcessEventPacket) from [<c0718b10>] (nicRxProcessRFBs+0xbc/0x188)
[  109.121197] [<c0718b10>] (nicRxProcessRFBs) from [<c0718ea8>] (nicProcessRxInterrupt+0x3c/0x40)
[  109.140739] [<c0718ea8>] (nicProcessRxInterrupt) from [<c07122bc>] (nicProcessIST_impl+0x5c/0xb4)
[  109.160488] [<c07122bc>] (nicProcessIST_impl) from [<c071236c>] (nicProcessIST+0x58/0xa4)
[  109.179554] [<c071236c>] (nicProcessIST) from [<c07045a8>] (wlanIST+0x50/0x9c)
[  109.197603] [<c07045a8>] (wlanIST) from [<c0722c2c>] (tx_thread+0x3bc/0x440)
[  109.215443] [<c0722c2c>] (tx_thread) from [<c0054350>] (kthread+0x118/0x120)
[  109.233280] [<c0054350>] (kthread) from [<c0010038>] (ret_from_fork+0x14/0x3c)
[  109.251348] ---[ end trace ef406c8ee8e40661 ]---
Edit 2: Good news! It seems the kernel was crashing on uninitialized memory. After I added the line below in drivers/misc/mediatek/connectivity/wlan/gen2/os/linux/gl_p2p_kal.c on line 1078, hostapd accepted the key handshake and no more kernel trace outputs :smiley:
memset(&rStationInfo, 0, sizeof(struct station_info));
@garywang: Could you please test and add this line to the repo?
Result:
Oct 18 22:14:46 alarm hostapd[438]: Using interface ap0 with hwaddr 02:08:22:10:f8:fc and ssid "BPI-R2"
Oct 18 22:14:46 alarm hostapd[438]: ap0: interface state UNINITIALIZED->ENABLED
Oct 18 22:14:46 alarm hostapd[438]: ap0: AP-ENABLED
Oct 18 22:15:35 alarm hostapd[438]: ap0: STA 38:ca:da:a0:f8:aa IEEE 802.11: associated
Oct 18 22:15:35 alarm hostapd[438]: ap0: AP-STA-CONNECTED 38:ca:da:a0:f8:aa
Oct 18 22:15:35 alarm hostapd[438]: ap0: STA 38:ca:da:a0:f8:aa RADIUS: starting accounting session ECFA0EF00D8C6ED2
Oct 18 22:15:35 alarm hostapd[438]: ap0: STA 38:ca:da:a0:f8:aa WPA: pairwise key handshake completed (RSN)
My device now indicates it is connected, although i didn’t setup any IP configuration yet. :slight_smile:
Edit 3: I just configured DHCP and NAT on the R2, seems to work perfectly in my limited test.
